    CleanUp - Time Required
    7 Posts 4 Posters 899 Views 4 Watching
      measuredmove
      Just started a Cleanup on a downloaded SU Warehouse model. The estimated time required to complete is 4hrs 5 min-could this be right?
      My 3D Catalogue
      https://3dwarehouse.sketchup.com/collection/103ed44c-a0c4-4049-9a84-89cd017bcc07/Measured-Move
      SU8/Brighter3D/Gimp/SimLab Composer
      • FrederikF Offline
        Frederik
        Depends on the complexity of the model...
        However, please note that the time shown is an estimate calculated...
        Most often the time it takes is much less than what the estimate is showing...
        Cheers
        Kim Frederik
          measuredmove
          That's correct it was quite a bit faster. Ended up being about 1hr and 51mins. With 800KB reduction in the file size.
          My 3D Catalogue
            Did you check the texture size? Sometimes textures can be large for no reason.
              measuredmove
              I did use the Resize Texture plugin but there were no textures-hidden or otherwise. Is there a way to quickly check the size of a texture? Perhaps not for this particlar file but in general.
              My 3D Catalogue
              • K Offline
                kaas
                I think the Goldilocks plugin reports texture sizes as well. Haven't used it recently though
                  measuredmove
                  Thanks,Kaas I forgot I had that plugin already and on a file with texture it does display the size-very handy.
                  My 3D Catalogue
