    Hole punch not working
    5 Posts 3 Posters 1.5k Views 3 Watching
    • pmolsonP Offline
      pmolson
      My very favorite plug in ever, and one I have used now for years is not working as expected in sketchup 2017
      For some reason the video capture does not show the drop down dialog box that I get when i right click and then select the hole punch option. But rest assured that is happening.
      As you can see from the video, the punch is not going through both skins of the wall and is also adding a surface where the window has already cut through the outer skin.
      I have used this window component and the hole punch tool thousands of times in sketchup 2016 with this exact procedure and it has worked like a champ.
      Any ideas what is going on.
      I have installed the latest version I could find. version 2.8
        I guess you refer to my http://sketchucation.com/pluginstore?pln=HolePunchTool
        I have a [long] list of some of my extensions which have been broken by the way v2017 handles entities' IDs.
        Thanks for the report.
        I also see the reported issue [although, weirdly there are no error-messages in the Ruby Console !]
        I'll investigate and try to find a fix...
        I have no idea [yet] what's up !
        πŸ˜•
        • pmolsonP Offline
          pmolson
          Yes, the holepunchtool...sorry about not stating that clearly.
            Maybe it will a good thing to put something in the Plugins Store
            for indicate Updated 2017 ?
              Until I get a report I don't know that it's bust!
              I'll put a warning the Plugin's main thread...
