    ๐Ÿ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    Parametric facade design
    9 Posts 4 Posters 3.0k Views 4 Watching
    • john2J Offline
      john2
      Any good tutorials on how the following type of facades can be easily made in sketchup?
      The facade was originally made in Rhino + grasshopper.
      I tried to intersect a terrain and a curved geometrical horizontal plane with my perforated screen pattern but that doesn't help.
      Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 โ€“ 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
        You have same like GrassHopper in SKetchUp! ๐Ÿ˜„
        Or more Simple! ๐Ÿ˜„
          Why not make like this ?
          And you make anything you want with the doted surface! ๐Ÿ˜„
          • Collage ArchitectureC Offline
            Just take a look at Transformer by S4U,It won't let you down! ๐Ÿ˜‰
            To Component and Face to Frame are also great plugin which will make you live an easier life.
            I love Sketchup
            • john2J Offline
              john2
              Thank you so much for this! I watched these videos with raised eyebrows literally!!!! ๐Ÿ˜ฎ Totally shocked,overjoyed and amazed.
              • panixiaP Offline
                panixia
                the "Flowify" plugin could be very helpful for this kind of shapes too..
                • john2J Offline
                  john2
                  The easiest way to become Frank O Gehry. Thanks a lot for this!! My mind was feeling dizzy as experienced in the theatre while watchign the shape shifting architecture of Inception and Dr. Strange.
                  • panixiaP Offline
                    panixia
                    it's a very useful (and robust) plugin.. you can model some simple flat shapes and then map them to curved surfaces.. here you can see an example of use.. a simple process to get a shape that would be not so easy and fast without flowify and a couple of oter plugins.. http://sketchucation.com/forums/viewtopic.php?f=397%26amp;t=66269
                    • john2J Offline
                      john2
                      Thanks a lot again! ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ˜„
