    Posting Renderings
    3 Posts 3 Posters 413 Views 3 Watching
    • G Offline
      garystan
      Hi everybody : Hopefully, this is the right place to post this question. When I "attach" a rendering (for posting), I noticed the "Place in line" button. What is that option ? Thanks............garystan
        It's for put images loaded inside the text of the message in the order that you want!
        (here with smileys)
        Line and rectangle or rectangle and line for example
        So you can load some images in any order then put them inside the text in any order wished!
        Press the little "+" for add images
        Then Press "Add Image" for upload all images
        Then "Place inline" in the text! (except the cube that I repeat above! πŸ˜„
        here images are at the end of the text! πŸ˜„
          It uses the phpBB BBcode to embed images into your posts like this...
          You can see when your are drafting your posts it wraps the image in BBcode...
          [attachment=0]loop-example-tig.gif[/attachment]
          Make reading your posts that bit more cleaner.
