    Black spots in darker areas
    renderpluginsextensions
    3 Posts 2 Posters 844 Views 2 Watching
    • M
      Mindaugiosha
      Hello,
      I'm rendering interior scene and I'm having some dark spots in darker areas. First I had many of them, but then increased hsph subdivis and samples to 64/50 in IM. I'm having much better result, but I want a better one, there is still dark spots on the wood on the right side (mulions). What settings should I increase? Here is screenshots, with first rendering and second.
      First rendering
      Second rendering
      • M
        Mindaugiosha
        Anyone? What settings should I correct?
        • panixiaP
          panixia
          i see those splotches in the floor and maybe a bit in the dark panels in the middle too.. try to render a separate raw gi pass, to better see how gi is working overall..
          assuming that everything else is fine in your irradiance map AND light cache setup.. i would try to reduce the color treshold value and see if that help..
