    Selecting connected lines along an edge?
    5 Posts 5 Posters 544 Views 5 Watching
      Chambint
      Is there any plugin or method to select all connected lines across an edge? I know there are plugins which can help just select all the edges of a face/component, but what if I want to specifically select one edge? For example when using the plugin curviloft, you can select all connected lines within 1 click when you are using it. So I would want something like this if possible.
      Thanks!
      • srxS Offline
        srx
        tt_select_curve
        www.saurus.rs
          An image ?
          else "Double click" don't make the trick ?
          • panixiaP Offline
            panixia
            sketchUV "path select tool" rules!
            http://sketchucation.com/forums/viewtopic.php?t=44501
              I generally use TIG's TIG-Weld plugin to weld edges together to make them easy to select. This other benefits, too, such as when extruding a face with Push/Pull or Follow Me.
