    Twilight Render Create Lights
    6 Posts 4 Posters 2.1k Views 4 Watching
    • sfto1S
      sfto1
      It's been quite some time since I used Twilight Render (Hobby), and I installed for my SU2017 today, and noticed that I cannot create lights. I thought I was able to do that previously. Is this a bug? or did they remove that feature from the Hobby version?
      Thanks in advance
      • tuna1957T
        tuna1957
        you should have access to the light editor with Twilight's hobby version. the appearance of the various Twilight editing windows did change some between TwilightV1 and TwilightV2 , could that have caused some trouble for you? Have you posted over on Twilight's user forum?
        • sfto1S
          sfto1
          I have not posted anything on the Twilight Forum, but the attached screen shot is what pops up when I activate the light tool
          • pbacotP
            The menus looked grayed out. On my Mac they are not. Regardless, do you get a cursor so you can place a light... that's what comes next, if you have no lights already to edit.
            • ntxdaveN
              ntxdave
              @sft01 I just tried it in 2017 and yes you see the dialog as you mention but as others have mentioned, you should see the cursor changes to look like a small hand. You can then do the normal three clicks in your model to create a light. The panel is initially showing up that way because you do not already have a light in your model.
              At least that is the way it is working for me but I do have the Pro version. I suggest you give it another try.
              Press F1...thank me later
              • sfto1S
                sfto1
                pbacot/ntxdave
                Thank you. I was able to place lights based on your suggestions.
                It's been log enough that I forgot how that worked.
