    Section plane is not hiding objects
    5 Posts 2 Posters 768 Views 2 Watching
    • 4 Offline
      4hotshoez
      I have a small section of my model that I want to isolate. I placed the first section plane and grouped it. Immediately after grouping, the objects in blue popped up behind the section, which I did not want. Then i added the second section plane, but it did not improve the problem (no surprise). What is happening?
      Objects circled in blue need to hide
      MufflerFinalRack28A-PartColor.skp
      SU 2016
      Win10 (64-bit), ASUS ZenBook Pro UX501J
      i7 2.6 Ghz, 16 GB RAM, 64-bit, 512 SSD
      NVIDIA GeForce GTX 960M, VRAM 2 GB
      32" Samsung SD850
        You have got your nested section-planes in something of a tangle...
        However, if you use active-sections with the:
        View > Component Edit > Hide Rest of Model...
        option to hide objects outside of the editing context,
        then it'll probably work as you hope.
        • 4 Offline
          4hotshoez
          I am not sure what you mean by a tangle. I have only one section plane nested in a group. Two of the three are active. Are you seeing something I am not?
          SU 2016
          32" Samsung SD850
          • 4 Offline
            4hotshoez
            AND... the "View > Component Edit > Hide Rest of Model... " works only when I select the group for editing.
            SU 2016
            32" Samsung SD850
              You misuse the term 'active' - only one section-plane can be 'active' in any given context.
              Having the nested section-plane allows you to cut what's inside its context [when it is active].
              Another section-plane outside of that group's context will cut everything in its own context, including the group which has the nested section-plane.
              You need to have both section-planes active to hide the loose geometry that is not inside of the group.
              Here's some screenshot showing it - in the original there two active section cuts and the bigger cut is looking towards the loose geometry, so it is visible - because it's outside of the group it's bound to be seen.
              The second shot shows the section cut in the opposite direction this time the loose stuff is not seen.
              Trying to do this with section-cuts alone is going to be very convoluted...
              If you want to hide that loose stuff I suggest you use the section-cuts as you have made them, but put that loose stuff on its own layer - which you then switch off in that scene - see the third screen-shot...
