    Add all components with same name to new group
    5 Posts 2 Posters 865 Views 2 Watching
    • G
      Gonvaz
      I've created some components that have the same name and I'd like to group them.
      I tried this:
      **mod = Sketchup.active_model
      @ent = mod.active_entities
      comps = Sketchup.active_model.definitions[@C_name]
      new_group = @ent.add_group comps
      new_group.name = "Layout**"
      But I'm doing something wrong (the group isn't created). Could you help me?
      • TIGT
        set up a pattern match:
        name=/^xxx/
        That matches everything starting with 'xxx'
        Then find all matching definition:
        comps = mod.definitions.find_all{|d| d.name=~name }
        Now you have an array of matching definitions by name-match.
        Process the active_entities to find all matching instances
        ins = mod.active_entities.find_all{|e| compos.include?(e.definition) }
        You now have an array of all matching instances.
        new_group = mod.active_entities.add_group(ins) new_group.name = "Layout"
        You now have a new group made from the instances.
        Note the instances must all be in the active_context...
        • G
          Gonvaz
          Thanks, TIG but...
             name=/^20x/
             comps = mod.definitions.find_all{|d| d.name=~name}
          74 ins = mod.active_entities.find_all{|e| comps.include?(e.definition)}
          Returns:
          Error: #<NoMethodError: undefined method definition' for #<Sketchup::Edge:0x0000000f893280>> C:/Users/jgv/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fill Surface.rb:74:in block in fill_surface'
          C:/Users/jgv/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fill Surface.rb:74:in each' C:/Users/jgv/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fill Surface.rb:74:in find_all'
          C:/Users/jgv/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fill Surface.rb:74:in fill_surface' C:/Users/jgv/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fill Surface.rb:12:in block in <top (required)>'
          SketchUp:1:in `call'
          • TIGT
            Sorry, I assumed the active_entities only contained instances.
            Here's a way to filter for just instances...
            ins = mod.active_entities**.grep(Sketchup::ComponentInstance)**.find_all{|e| comps.include?(e.definition)}
            Substitute this line for the similar line in the code...
            • G
              Gonvaz
              I was blind, now I can see.
              Thank you, TIG.
