    Arrrg! what did I do? Error!
    4 Posts 3 Posters 521 Views 3 Watching
      CalypsoArt
      Setting up my 2017 to match my 2016. It was working but now this error. All I did was set the preferences to a different folder for Materials.
      http://calypsotheatrical.com/link_images/error2017.JPG
        CalypsoArt
        Ok. Went back to the default Materials folder and the problem is solved. I can't believe I can't use a different path for materials. Maybe I did something else wrong.
        • cottyC Offline
          cotty
          mkdir (make directory) error sounds like missing write permissions for that folder?
          my SketchUp gallery
          • Tyler MillerT Offline
            Tyler Miller
            More than likely, you are not running SketchUp 2017 as an administrator. In order to make a directory anywhere under the Program Files folder, you must have admin rights in Windows. In general, storing user documents of any type under Program Files is discouraged by Microsoft. We finally corrected where SketchUp reads and writes content files (like materials) in SketchUp 2017.
            If you are going use a custom Materials folder other than the SketchUp 2017 default, I would suggest placing it under your Documents folder where you have read and write rights, even if not running as an administrator.
            Hope that helps,
            Tyler
