    Wish list for Sketchup 2018
    125 Posts 50 Posters 216.8k Views 50 Watching
      cuttingedge
      Most of my wishes are repeated every year. and i repeat again:
      1. MULTIPLE VIEWPORT
      • every serious modeler (at least for most 3d platform) use multi-viewport. It is a feature that is essential to most 3d package . Hopefully we get an extra window that can be assigned left, right, top etc.
      1. QUADs
        I hope there's a quad-mode feature that can be turned on that will prevent triangulation when modifying quad geometries. I hope to really be able to work in quads without any complication.
      2. More solid all-in-one UVW, UNWRAPPING & TEXTURE BAKING solution all within SU.
        jonathonlt
        @john sayers said:
        I would like the Windows version to have 2 or more files open at once - I gather the Mac version already has this feature.
        see if this works , if I try and move it I PROBARBLY loose it ,,my relavent post is in DEVELOPERS FORUM headed DOC MULTIPLE MODELS the NEW (full) pic did not upload and I am short of line time from Jon
        I would try ,,cross reference organiser tho 14 day trial would not load ,,probarbly more than a single user needs,, I still work with my collage A3 drawing board , and can often have many drawings to hand,, multiple SU opened has no flow ,,so here is an idea of how it could possibly work ,if one of those those magic programmer,s "clock it" Jon ,,,
        docked models could have a user default size and window position so swapping is immediate ,,successive models ,,the same,, to unclutter the view ,floating model commands ,use the main toolbar choices,,>>> cliq M-doc,, > open doc models folder ( same as model folder) select 1 or more models > cliq open ,,this then loads all reference models needed to M-doc > float over doc to select,> this and a few more intracuss,s er might create a work flow JON ,,trying,,
          mark_melb
          It would be great if the PDF functionality on the Apple version of Sketchup can be had on Windows.
          • jujuJ Offline
            juju
            I may be wrong, but I think that is built into Mac OSX, not into the Mac OSX version of SketchUp.
              Juju is correct. It would be great if Microsoft would add the same sort of functionality Apple has for PDF files.
              • P Offline
                pipingguy
                Solve minor issue where you are being notified that you are about to modify a component ("do want to make this unique?"), when in fact, it's really a group. Other times when you attempt to modify a component, the warning does not appear.
                • P Offline
                  pipingguy
                  Sometimes, when you launch LayOut - or already have it running, but decide to open an additional drawing, you wait and wait until you happen to notice the Windows taskbar icon turned blue, at which point you click it. Let's get that fixed.
                    SketchUp doesn't warn you of modifying components natively. Are you sure you don't have a plugin/extension delivering that message?
                    AshScott's Edit Flag creates that popup message. You could uninstall it and satisfy one item on your wishlist.
                    • P Offline
                      pipingguy
                      to Dave's point...I will watch for the next time the edit warning pops up so i can screen-grab it.
                      • BoxB Offline
                        @pipingguy said:
                        When re-scaling a group or component, the tape measure tool is used. However, more often than not, one needs to go thru the extra step of erasing the resultant guideline before closing the group or component. let's fix that.
                        Done correctly no guideline is created.
                        As I'm on my phone I cannot demonstrate it for you.
                        • P Offline
                          pipingguy
                          When re-scaling (re-sizing) a group or component, the tape measure tool is used. However, more often than not, one needs to go thru the extra step of erasing the resultant guideline before closing the group or component. let's fix that.
                            As it's not a native SketchUp function to bring up this message, it's within your capability to prevent it from showing.
                              rv1974
                              The Print screen above looks like a bad trip. Heaven forbid! ๐Ÿ˜ฒ
                              • P Offline
                                pipingguy
                                BOX suggests a guide need not be left as a remnant when resizing. I can understand that when the object is rectangular. Just drag the tape measure along an edge from a corner - but what if you wanted to resize a cylinder's diameter?
                                • BoxB Offline
                                  @pipingguy said:
                                  BOX suggests a guide need not be left as a remnant when resizing. - but what if you wanted to resize a cylinder's diameter?
                                    AS Box shows, no guideline needs to be created but even when you do have guidelines to get rid of, why don't you setup a keyboard shortcut to delete guides?
                                    • kenK Offline
                                      ken
                                      Just found this thread and haven't read all the request.
                                      I have a simple request, somehow, make all the "Sketchup toolbars" be listed at the beginning of the view toolbars ahead of all the imported toolbars or at least clustered. Example, rename all the Sketchup toolbars as SK_Construction or SK_Drawing to get them clustered in the SK region.
                                      Now is that too much to ask for?
                                      Ken
                                      • pbacotP Offline
                                        Ken
                                        Is this the same as the menu item "View / Tool Palettes" on the Mac? Mine were never alphanumerically listed. I can't figure out why SketchUp has abandoned A-N listings in various lists. Just annoying to have to scan/search for things in this day and age. The Extensions tab is another example.
                                        • Mistro11M Offline
                                          Mistro11
                                          The main thing I been waiting for is better UV mapping tools.....like many other 3D modeling programs have. When making game assets I have to port everything to Blender to finish. It would be great if we could stay in Sketchup to the end.
                                          i7-4930k @3.4/3.7GHz, 32Gb RAM, NVidia GTX 980Ti 6Gb, Windows 7 Pro 64bit
                                          Structural Integrity is Not Just Physical...It's in the Design and Purpose
                                          • P Offline
                                            pipingguy
                                            Unlike Box' GIF, I always get an infinite guideline when i stretch my tape measure tool across a cylinder's end. what am i doing wrong? As for erasing unwanted guidelines and guidepoints with a SHORTCUT KEY - i actually use them as permanent column lines and other points of reference - and so, a global erasure would not serve me well.
                                            • 6
                                            • 7
                                            • 6 / 7
