    Modeling Battlefleet Gothic
    2 Posts 2 Posters 321 Views 2 Watching
      matsuo_lano
      Hi all,
      I've been working on several projects inspired by the tabletop game Battlefleet Gothic. When I start modeling I use the Curviloft plugin-in (skinning of shapes option) to shape the bow. The problem is that the results aren't that predictable at times. Are there any alternatives? Or could I use the plug-in in a better way?
      Attached is the kind of bow I try to model.
      You try to rearrange me 'till I'm sane
      • K Offline
        kaas
        nice challenge!
        When working with curviloft I get the best results if:
        • I have the same segment count in every profile + vertices at the same relative position
        • If possible, I only make 1 half and mirror the final result. Its more easy modelling and no problem determining which vertex is the start of the profile etc
        • with complex shapes I sometimes only loft a few segments at a time and afterwards attach those lofts together (split the whole shape up in multiple parts if needed)
