    Create reverse 360 degree view
    renderpluginsextensions
    2 Posts 2 Posters 631 Views 2 Watching
    • V Offline
      vigge50
      Hello
      I found for some time ago the function of making a 360 degree view inside a model and then upload it on my website and I thought it was great because it makes a mush better felling of the model then a picture.
      Now I thought that maybe it was possible to do the reverse, wish means that you could look at the model and rotate it like you can do in Sketchup Warehouse. Is this possible or does the hole model have to be uploded like the warehouse and without the possibility to use vray?
      If there doesn't exist a function its maybe possible to do a picture library with a lot of picture there it's easy to drag between several picture at ones and by that way make it feels that you rotate the object.
      • jiminy-billy-bobJ Offline
        jiminy-billy-bob
        You need to use something like "Object2VR" or similar.
