    Flatten 3D model to 2D
    7 Posts 5 Posters 7.8k Views 5 Watching
    • brettsichellodesignB Offline
      brettsichellodesign
      Just a quick question.
      Has anyone got a way to flatten a 3D model to 2D?
        http://sketchucation.com/pluginstore?pln=FlattenToPlane
        this also needs
        http://sketchucation.com/pluginstore?pln=WorkPlane
          brettsichellodesign
          http://i67.tinypic.com/21b9obk.jpg
          That didn't go well.
          I'll try experimenting a bit more. Thanks for the help though Tig.
          • G Offline
            Glenn at home
            One way that works is to set you view. Then go and export a 2D DWG file. Then import this new 2D dwg file back into SU. Yes, only works in the Pro version.
            https://dl.dropboxusercontent.com/u/2124177/SU flatten.jpg
              brettsichellodesign
              Thanks Glenn. Wish I'd thought of that.
                colbsnugget
                Works best to just export in Top View, Parralel Projection to a DWG and then re-import it into the model.
                • chippwaltersC Offline
                  chippwalters
                  I've had good luck with the Unwrap and Flatten Faces plugin.
                  https://extensions.sketchup.com/en/content/flatten-faces
                  Used it just yesterday with Flowify to create the rolled up reality board in this pic:
                  https://filedn.com/lLMW4jXsJqxXkRYjd1UCoKL/3d/untitled.194.jpg
                  Currently working with Cross-Reality technologies
