    [URGENT] Vray Stops rendering displacement!!!
    renderpluginsextensions
    3 Posts 3 Posters 737 Views 3 Watching
    • N
      NMoeini
      Hi Guys,
      I've been struggling with this issue for a while now. I'm trying to create a gravel material which has both bump and displacement. But Each time I tried it turned out flat. I copied just the material into a new file and it works just fine. Seems when the files gets heavy or complicated it doesn't render properly. Any Suggestions?
      PS: I tried purging everything and it wiped out all the effects an all of the other materials as well. So any solution beside purge?
      • V
        valerostudio
        It must be applied to a group.
        • andybotA
          andybot
          meaning the gravel material has to a be grouped by itself so there is only one material in the group - more info here: http://sketchucation.com/forums/viewtopic.php?f=322%26amp;t=28593
