    SketchUp 2015 (Mac) Component panel freezing application
    7 Posts 4 Posters 1.1k Views 4 Watching
    • K
      kado
      In one particular file only, whenever I attempt to open the Components panel, the app stops responding forcing me to force quit and re-open.
      I've even exploded every single component in the file, saved as new file, re-opend and tried opening the Components panel with the same result.
      What else can I try to recover this model?
      Thanks for any advice.
        Try Window>Model Info>Statistics>Purge Unused.
        • K
          kado
          Thanks for the reply. Followed your suggestion with no luck.
          • S
            slbaumgartner
            How many components are in the model or the collection you are viewing? I've seen the components window freeze SketchUp (spinning beachball of death) while generating the thumbnails for a large list of components. If I wait long enough, it eventually wakes up. Having a lot of unused components in the model aggravates this problem.
            • K
              kado
              92 components with 3,500 instances. Strange thing is, even with every single component exploded (as an experiment) the same behaviour occurs.
              • jujuJ
                juju
                in your experiment, did you remember to purge the file after exploding all of the components?
                • S
                  slbaumgartner
                  I agree with Juju: with every component exploded, there should be nothing to list in the component browser and the response should be snappy - unless you are trying to browse a large collection, not the in-model collection. In the latter case it may still be so large as to bog down the browser, or a slow/lagging network connection can affect it.
