Entity is a group instead of a solid group
I have a relatively complicated model of a train station that I'm trying to simplify into a single solid group to be 3D printed. I have used Solid Inspector2 and it turns out that there are no errors in the model. So I'm a tad confused what can I do to resolve this issue? Do I need to redo the model
Tools that check solidity are not foolproof.
Have you tried my own SolidSolver ?
http://sketchucation.com/pluginstore?pln=TIG_solidsolver
It uses slightly different algorithms...It is one step undo-able...
Thanks, I'll take a look into it.
Register LoginAdvertisement
