    How do I fix this error ?
    5 Posts 4 Posters 1.1k Views 4 Watching
    • F Offline
      Frankduj
      I've just downloaded Sketchup 8 and then dowwnlosded the extensions V3.0.1 and instead of getting a Plug in icon I ended up with this error message :
      Error Loading File SketchUcation.rb
      (eval):235:in `require': uninitialized constant SketchupExtension::SCF::FOLDER
      Any help will be greatly appreciated.
      Thanks.
      Frank
      • jujuJ Offline
        juju
        Hi Frank, welcome to SketchUcation. I trust you will find this community helpful.
        How to fix the problem, download SketchUp 2016 Make...? Or greater than version 8 for that matter.
        SketchUcation ExtensionStore v3.0.1
        Dependencies: Use v3.0 >v8, or stick with v2.6... for earlier SketchUp versions...
        SketchUp 8 is several years old, I don't even know where you could have downloaded it from...
        • TIGT Online
          Unfortunately SketchUp v8 is no longer supported by Trimble, and as a result also not by several extensions which have been upgraded to run on newer versions.
          The Toolset's Usage notes say,
          "...If upgrading, install then restart SketchUp to finalize... <=v8 stick with v2.6...".
          As @juju said, it also says,
          "Dependencies: Use v3.0 >v8, or stick with v2.6... for earlier SketchUp versions..."
          And its compatibility notes do not list v8.
          Also note that v2013 will probably not be supported in the near future...
          So v2016 is recommended...
          • F Offline
            Frankduj
            Thanks Juju & TIG,
            Your advice and feedback have been a great help to me.
            Frank
              Not likely a legitimate source.
