    πŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    Bright Yellow Default Settings in Vray for SketchUp
    renderpluginsextensions
    5 Posts 3 Posters 2.2k Views 3 Watching
    • I Offline
      igendreau
      I'm clicking the Load Defaults button, and only making one change. That change is to click the "Override Materials" checkbox in the Global Switches. But when I render my scene, with shadows set to today's date and noon as the time, it renders as totally yellow. Like, really yellow. If I go into Environment, I don't see anything with a yellow color. Any idea why this would be?
      http://www.scroll-left.com/downloads/yellow.jpg
        Please provide more information. What rendering application are you using that is causing this?
        • I Offline
          igendreau
          I am using VRay 2 for SketchUp.
            I fixed the title so that you might get some help.
            • 3dita3 Offline
              3dita
              Hi there! Change the time settings in the Shadows panel. Usually setting the correct time zone, will get you correct day light.
              3dita - Digital Visual Motion
