    PDF File within Resource Files Axes Manager Download
    extensions
    2 Posts 2 Posters 973 Views 2 Watching
    • D
      Daniel57
      I downloaded an extension called Axes Manager and on the page I got it from it states, "PDF doc file can be found in the Resources folder of the plugin, and tips to localize your version as well". I cannot find the Resources Folder that came with it nor can I find it anywhere in the program files. Is there something on SketchUp itself where one can access such files ? I tried even downloading the app separately to see if I could get the PDF file that way but no dice. I have Windows 10 and the edition I have is SketchUp Make 2016. Other extensions must have PDF files included in them, but this is the first I've run into. Thanks !
      • TIGT
        Where did you get 'Axes Manager' from ?
        Do you mean something else ?
        There is a 'UCS Manager' RBZ [DBUR_UcsManager.rbz] available from the SketchUcation Pluginstore
        http://sketchucation.com/pluginstore?pln=DBUR_UcsManager_v1_0_0
        When properly install it has a subfolder named 'DBUR_UcsManager' in which is a Resources subfolder, which contains the PDF [UCS Manager.pdf].
        The EWH includes a newer one by Didier named 'Axes Manager' ?
        With similar files/subfolders 'DBUR_AxesManager.rbz' etc.
        There is a Resources subfolder containing 'Axes Manager 2016.pdf' ?
        So How did you install it ?
        Using Windows > Preferences > Extensions > Install Extension... button ?
        I have just installed both from their RBZ and they both include the PDF in the ../Plugins/DBUR_XxxxManager/Resources subfolder...
