    Recover an image from a batch render that did not save?
    renderpluginsextensions
    3 Posts 2 Posters 3.6k Views 2 Watching
      sasasaps
      Sometimes, after leaving a batch to render, with a correct Output File path (including a file name for the selected ".vrimg" extension), and with "Save to output" and "Render to VRImage" enabled, I GET NO OUTPUT FILE at all.
      This has happened to me sometimes, and needless to say, it is very frustrating.
      My question is, is there any way to recover files that have been previewed in the Frame Buffer?? Or, is there any temporary folder where I can find data of my previously rendered scenes??, and if that is the case, how can I use that data and transform it into an image file.
      I use VFS 2.0 on Sketchup 2015.
      Your help would be much appreciated.
      • V Offline
        valerostudio
        I have had this same issue in the past. Make sure there are no characters in your file name at all, even the folders. We had an "&" in our project name that VR did not like that at all.
        Now I also render all finals into a folder on my desktop to shorten any issues with folder structure as well.
          sasasaps
          Thank you for your reply. Good to get this tips about bugs discovered by experience!
          About the Vray Frame Buffer I still think it is a bit rigid and something as useful as recovering a past file rendered in it should be possible. It is quite easy to loose work with how it works...
          I am curious, is there something in the 3ds max Frame Buffer that Vray could still learn from?
