    Foundation Plugin
    448 Posts 15 Posters 456.4k Views 15 Watching
    • medeekM Offline
      medeek
      Any call for drain pipe around the footing of these foundations?
      Pipe diameter? 4", 6" How accurate do you want it to be? Any pipe specs that are normally used? I've never actually installed drain pipe around a footing so my experience with it is minimal other than calling out a 4" drain pipe on various plans.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • jujuJ Offline
        juju
        rather leave that as a separate element the user can add, if and as per their requirements
        • K Offline
          KrisM
          I have a previously purchased copy of the Foundation plugin. I have just been notified when I started SketchUp that a new version is available. I go to the Medeek website and find the sentence that says go to Account Manager for the update. Log into Account manager but for the life of me, I can't find any way to get the current version. Am I supposed to download a trial version? Am I missing something obvious? I had the same trouble with the Truss plugin and never updated it. Any help would be appreciated.
          KrisM
            MtnArch
            This is how I do it: after you've logged into your account it should bring up the main screen that has the Plugins towards the bottom of the page. Pick on either one (say, the truss plugin), then when it shows your order number pick on it. At that window it should say "Download Now" at the top - pick that and save the new version to your computer.
            Highest Regards,
            Alan T. Hendry, RA
            Architect
            • K Offline
              KrisM
              Worked like a charm. Thank you.
              I would suggest that a sentence or two could be put in the Account manger page to explain this. Sometimes the obvious ... isn't.
              • medeekM Offline
                medeek
                I apologize for the obvious confusion in where to go to download the latest version. I will look into this further and update the Account Manager accordingly.
                design.medeek.com
                • K Offline
                  KrisM
                  Thanks for your response. I acknowledge and applaud your always being on top of things.
                  • medeekM Offline
                    medeek
                    You give me too much credit, if I was on top of things we wouldn't be having this conversation.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Okay, try it now...
                      Login to the Account Manager and click on either the Truss Plugin or the Foundation Plugin. If you have an active license (not expired) a download button/link will now show rather than a purchase or renew button. Once your plugin serial expires the button will revert to a renew and/or purchase button. Not sure why I didn't fix this before, it was not a big deal.
                      If you click on your order number you will also see the download link as well. Just one less hoop to jump through.
                      design.medeek.com
                      • N Offline
                        nujak66
                        Love the Video Tutorial Nathaniel!
                        • medeekM Offline
                          medeek
                          The renewal option is now available for the foundation plugin. The current renewal cost is $7.00 USD versus a $10.00 USD new license fee.
                          design.medeek.com
                          • TandemT Offline
                            Tandem
                            Great news for all licensed users of the Medeek Foundation Plugin.
                            Nathaniel just updated the Medeek Construction Library KickStarter project by adding a pledge that lets people upgrade their existing Foundation Plugin license to the Construction Library license for $35.
                            • medeekM Offline
                              medeek
                              Version 1.1.5 - 07.18.2017
                              • Fixed bug with slab reinforcement for Slab-on-Grade foundations (Polygon, Face).
                              design.medeek.com
                                dpaul
                                I have just started to experiment with the foundation plugin. The parametrics are great.
                                A question: might it be possible to have defaults for joists flush with the mud sill, i.e. to have the floor
                                assembly sit WITHIN the foundation wall?
                                With my thanks.
                                • pbacotP Offline
                                  With my thanks.
                                  This is an increasingly typical condition for us too. The sheathing extends over the mudsill. Then we also have the condition where we raise the stemwall even higher to raise the wall framing above adjacent decks.
                                  • facerF Offline
                                    facer
                                    8 Aug Update
                                    • facerF Offline
                                      facer
                                      Medeek Const Library - Kickstarter Status at: 14 Aug
                                      • facerF Offline
                                        facer
                                        Medeek Const Library - Kickstarter Status at: 20 Aug
                                        All or nothing. This project will only be funded if it reaches its goal by Tue, August 29 2017
                                        Just a moment...
                                        (www.kickstarter.com)
                                        • facerF Offline
                                          facer
                                          Medeek Const Library - Kickstarter Status at: 26 Aug
                                          • medeekM Offline
                                            medeek
                                            I've been considering adding in a waffle (pod) slab, the type that is common in Australia.
                                            I've also been reading quite a few online articles that discuss some of the issue with this type of foundation:
                                            https://www.cornellengineers.com.au/beware-waffle-slabs/
                                            There does seem to be some advantages to this system but also some disadvantages.
                                            https://wpma.org.au/members/members
                                            Just wondering if anyone has any direct experience good or bad with this type of foundation system that they would be willing to share.
                                            design.medeek.com
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 22
                                            • 23
                                            • 9 / 23
