    Foundation Plugin
    451 Posts 15 Posters 540.5k Views 15 Watching
      db11
      I'll get to answering your questions later today, when I have some open time. In the meantime here are screenshots of the foundation / detail drawings (sans cartouche).
      Foundation Plan
      EPS Tray
      Construction Section
      Foundation Detail
      • medeekM Offline
        medeek
        With your EPS form profile I am wondering what the function of the foot is that overshoots the exterior wall. Wouldn't an L-shaped profile work just as well?
        Nathaniel P. Wilkerson PE
        Medeek Engineering Inc
        design.medeek.com
        • N Offline
          nujak66
          @medeek said:
          I've had some discussion with other SketchUp users about developing the plugin for commercial use. Should I require that the user have PRO installed? A number of registered users of the plugin do not use it for commercial use, I would rather keep it open to all users but it would be easier to develop within PRO with its Boolean functions.
          I say if it furthers your development, then make it for the PRO version.
            Garry K
            For what ever it is worth I believe I share this sentiment with Nathaniel. I want my plugins to work with Make and Pro.
            However I do use a few Pro only features. What I do is disable them in the web dialog if Make is running. So I can manage one source code and not worry. The features that I disable are not show stoppers.
            • medeekM Offline
              medeek
              Tutorial 1:
              design.medeek.com
              • medeekM Offline
                medeek
                Version 1.1.4 - 06.11.2017
                • Added pre-drawn face outline tool for stemwall and slab-on-grade foundations and slabs.
                You can now click on a face (any closed polygon shape) and the plugin will generate the appropriate stemwall, SOG or slab.
                design.medeek.com
                • medeekM Offline
                  medeek
                  Any call for drain pipe around the footing of these foundations?
                  Pipe diameter? 4", 6" How accurate do you want it to be? Any pipe specs that are normally used? I've never actually installed drain pipe around a footing so my experience with it is minimal other than calling out a 4" drain pipe on various plans.
                  design.medeek.com
                  • jujuJ Offline
                    juju
                    rather leave that as a separate element the user can add, if and as per their requirements
                      KrisM
                      I have a previously purchased copy of the Foundation plugin. I have just been notified when I started SketchUp that a new version is available. I go to the Medeek website and find the sentence that says go to Account Manager for the update. Log into Account manager but for the life of me, I can't find any way to get the current version. Am I supposed to download a trial version? Am I missing something obvious? I had the same trouble with the Truss plugin and never updated it. Any help would be appreciated.
                      KrisM
                        MtnArch
                        This is how I do it: after you've logged into your account it should bring up the main screen that has the Plugins towards the bottom of the page. Pick on either one (say, the truss plugin), then when it shows your order number pick on it. At that window it should say "Download Now" at the top - pick that and save the new version to your computer.
                        Highest Regards,
                        Alan T. Hendry, RA
                        Architect
                          KrisM
                          Worked like a charm. Thank you.
                          I would suggest that a sentence or two could be put in the Account manger page to explain this. Sometimes the obvious ... isn't.
                          • medeekM Offline
                            medeek
                            I apologize for the obvious confusion in where to go to download the latest version. I will look into this further and update the Account Manager accordingly.
                            design.medeek.com
                              KrisM
                              Thanks for your response. I acknowledge and applaud your always being on top of things.
                              • medeekM Offline
                                medeek
                                You give me too much credit, if I was on top of things we wouldn't be having this conversation.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Okay, try it now...
                                  Login to the Account Manager and click on either the Truss Plugin or the Foundation Plugin. If you have an active license (not expired) a download button/link will now show rather than a purchase or renew button. Once your plugin serial expires the button will revert to a renew and/or purchase button. Not sure why I didn't fix this before, it was not a big deal.
                                  If you click on your order number you will also see the download link as well. Just one less hoop to jump through.
                                  design.medeek.com
                                  • N Offline
                                    nujak66
                                    Love the Video Tutorial Nathaniel!
                                    • medeekM Offline
                                      medeek
                                      The renewal option is now available for the foundation plugin. The current renewal cost is $7.00 USD versus a $10.00 USD new license fee.
                                      design.medeek.com
                                      • TandemT Offline
                                        Tandem
                                        Great news for all licensed users of the Medeek Foundation Plugin.
                                        Nathaniel just updated the Medeek Construction Library KickStarter project by adding a pledge that lets people upgrade their existing Foundation Plugin license to the Construction Library license for $35.
                                        • medeekM Offline
                                          medeek
                                          Version 1.1.5 - 07.18.2017
                                          • Fixed bug with slab reinforcement for Slab-on-Grade foundations (Polygon, Face).
                                          design.medeek.com
                                            dpaul
                                            I have just started to experiment with the foundation plugin. The parametrics are great.
                                            A question: might it be possible to have defaults for joists flush with the mud sill, i.e. to have the floor
                                            assembly sit WITHIN the foundation wall?
                                            With my thanks.
                                            With your input, this post could be even better šŸ’—
                                            • 11
                                            • 22
                                            • 23
                                            • 9 / 23
