    Foundation Plugin
    449 Posts 15 Posters 461.8k Views 15 Watching
    • medeekM Offline
      medeek
      Tutorial 15 - Multi-Step Foundations (8:24 min.)
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 2.0.8 - 03.01.2026
        • Updated the SOG draw tool with a more robust "face" draw option.
        This update per customer request.
        design.medeek.com
        • medeekM Offline
          medeek
          Version 2.0.8b - 03.02.2026
          • Updated the Slab draw tool with a more robust "face" draw option.
          design.medeek.com
          • medeekM Offline
            medeek
            Version 2.0.9 - 03.03.2026
            • Added a "Separate Callouts" option for stemwall foundations into the General tab of the Global Settings.
            • Separate callouts for stemwall foundations display the volume for footing and stemwall portions independently.
            design.medeek.com
            • medeekM Offline
              medeek
              Version 2.1.0 - 03.05.2026
              • Enabled quantity 4 and 5 bars of footing rebar for stemwall and stemwall step foundations.
              I did not update the legacy stemwall tool since I will be retiring that tool eventually but I have not decided on a date just yet.
              design.medeek.com
              • medeekM Offline
                medeek
                Version 2.1.1 - 03.06.2026
                • Added a "Material Weights" section to the General tab of the Global Settings.
                • Added Weight Callouts as an option for grade beam assemblies.
                The density of the concrete, CMU and steel can all be customized in the global settings as shown in the image above. I will probably enable this feature for other foundation assemblies if it is requested.
                design.medeek.com
                • gullfoG Offline
                  gullfo
                  very useful. for my purposes, since most recording studio isolation is mass, i have my spreadsheet to calculate the walls, floor, and ceiling structure. this includes framing, sheath layers, insulation, and for my estimation electrical, plumbing, ducts, windows, doors, and absorption assemblies. i think the former layers in the floor, wall and perhaps truss would also be helpful (i use trusses to suspend interior ceilings on load bearing walls when i have long spans where a simple joist won't handle it, like a live room)
                  Glenn
                  http://www.runnel.com
                  • medeekM Offline
                    medeek
                    Version 2.1.2 - 03.07.2026
                    • Added Weight Callouts as an option for polyline stemwall assemblies.
                    • Added Weight Callouts as an option for stemwall step assemblies.
                    For this detailed breakdown you need to have the "separate callouts" and "weight callouts" both enabled.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Version 2.1.3 - 03.15.2026 thru 03.16.2026
                      • Created the Medeek Foundation API.
                      • Enabled the following methods within the Medeek Wall API: sog_draw, validate_medeeksog, sog_move, sog_regen, sog_read_attributes, sog_read_attribute, sog_set_attribute
                      • Added the Medeek Wall API Documentation page to the website.
                      • Added the Medeek Foundation API - Slab-on-Grade Attribute Library Index page to the website.
                      Medeek Foundation API Documentation
                      (design.medeek.com)
                      (design.medeek.com)
                      design.medeek.com
                      • 19
                      • 20
                      • 21
                      • 22
                      • 23
                      • 23 / 23
