Foundation Plugin
Version 2.0.0 - 06.27.2024
- Fixed a bug in the rebar module for stemwall step assemblies.
- Added the following Simpson column bases to the built-in library: CPT44Z, CPT66Z, CPT88Z
http://design.medeek.com/resources/foundationplugin/images3/foundation_su128_800.jpg -
Version 2.0.1 - 08.01.2024
- Added a duplicate foundation assembly check to the regen module for the following foundation types: Stemwall, SOG, Slab, Stemwall Step, Grade Beam, Strip Footing, Footing.
The instructions for usage are the same as the recent update to the Wall plugin, see Wall Plugin Tutorial #51:
Version 2.0.2 - 08.07.2024
- Fixed a bug in the wireframe preview for polyline stemwalls.
- Fixed a bug with horizontal rebar for polyline stemwall foundations (closed, RIGHT direction).
- Added the stemwall "Hide Edges" parameter to the General tab of the Global Settings.
Tutorial 13 - Framing Basement Walls (15:17 min.)
Version 2.0.3 - 03.23.2025
- Enabled removal of individual anchor bolts for (polyline) stemwall and slab-on-grade foundations.
- Enabled addition of custom location anchor bolts for (polyline) stemwall and slab-on-grade foundations.
Tutorial 14 - Managing Anchor Bolts (12:13 min.)
Version 2.0.4 - 03.27.2025
- Enabled removal of individual anchor bolts for stemwall step foundations.
- Enabled addition of custom location anchor bolts for stemwall step foundations.
Version 2.0.7 - 02.05.2026
- Fixed a bug with the (double) stemwall step when the ICF option is active.
Tutorial 15 - Multi-Step Foundations (8:24 min.)
Version 2.0.8 - 03.01.2026
- Updated the SOG draw tool with a more robust "face" draw option.
This update per customer request.
Version 2.0.8b - 03.02.2026
- Updated the Slab draw tool with a more robust "face" draw option.
Version 2.0.9 - 03.03.2026
- Added a "Separate Callouts" option for stemwall foundations into the General tab of the Global Settings.
- Separate callouts for stemwall foundations display the volume for footing and stemwall portions independently.
Version 2.1.0 - 03.05.2026
- Enabled quantity 4 and 5 bars of footing rebar for stemwall and stemwall step foundations.
I did not update the legacy stemwall tool since I will be retiring that tool eventually but I have not decided on a date just yet.
Version 2.1.1 - 03.06.2026
- Added a "Material Weights" section to the General tab of the Global Settings.
- Added Weight Callouts as an option for grade beam assemblies.
The density of the concrete, CMU and steel can all be customized in the global settings as shown in the image above. I will probably enable this feature for other foundation assemblies if it is requested.
very useful. for my purposes, since most recording studio isolation is mass, i have my spreadsheet to calculate the walls, floor, and ceiling structure. this includes framing, sheath layers, insulation, and for my estimation electrical, plumbing, ducts, windows, doors, and absorption assemblies. i think the former layers in the floor, wall and perhaps truss would also be helpful (i use trusses to suspend interior ceilings on load bearing walls when i have long spans where a simple joist won't handle it, like a live room)
Version 2.1.2 - 03.07.2026
- Added Weight Callouts as an option for polyline stemwall assemblies.
- Added Weight Callouts as an option for stemwall step assemblies.
For this detailed breakdown you need to have the "separate callouts" and "weight callouts" both enabled.
Version 2.1.3 - 03.15.2026 thru 03.16.2026
- Created the Medeek Foundation API.
- Enabled the following methods within the Medeek Wall API: sog_draw, validate_medeeksog, sog_move, sog_regen, sog_read_attributes, sog_read_attribute, sog_set_attribute
- Added the Medeek Wall API Documentation page to the website.
- Added the Medeek Foundation API - Slab-on-Grade Attribute Library Index page to the website.
Version 2.1.4 - 04.13.2026
- Enabled quantity 4 and 5 bars of footing rebar for strip footings.
Version 2.1.5 - 07.20.2026
- Added a SOG "profile" edit tool within the context menu for polygon slab-on-grade assemblies.
- Added a "Grid Snap" option with hotkey (End key) into the SOG profile edit tool.
