    Foundation Plugin
    451 Posts 15 Posters 614.5k Views 15 Watching
    • medeekM
      medeek
      Version 2.0.8 - 03.01.2026
      • Updated the SOG draw tool with a more robust "face" draw option.
      This update per customer request.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Version 2.0.8b - 03.02.2026
        • Updated the Slab draw tool with a more robust "face" draw option.
        design.medeek.com
        • medeekM
          medeek
          Version 2.0.9 - 03.03.2026
          • Added a "Separate Callouts" option for stemwall foundations into the General tab of the Global Settings.
          • Separate callouts for stemwall foundations display the volume for footing and stemwall portions independently.
          design.medeek.com
          • medeekM
            medeek
            Version 2.1.0 - 03.05.2026
            • Enabled quantity 4 and 5 bars of footing rebar for stemwall and stemwall step foundations.
            I did not update the legacy stemwall tool since I will be retiring that tool eventually but I have not decided on a date just yet.
            design.medeek.com
            • medeekM
              medeek
              Version 2.1.1 - 03.06.2026
              • Added a "Material Weights" section to the General tab of the Global Settings.
              • Added Weight Callouts as an option for grade beam assemblies.
              The density of the concrete, CMU and steel can all be customized in the global settings as shown in the image above. I will probably enable this feature for other foundation assemblies if it is requested.
              design.medeek.com
              • gullfoG
                gullfo
                very useful. for my purposes, since most recording studio isolation is mass, i have my spreadsheet to calculate the walls, floor, and ceiling structure. this includes framing, sheath layers, insulation, and for my estimation electrical, plumbing, ducts, windows, doors, and absorption assemblies. i think the former layers in the floor, wall and perhaps truss would also be helpful (i use trusses to suspend interior ceilings on load bearing walls when i have long spans where a simple joist won't handle it, like a live room)
                Glenn
                http://www.runnel.com
                1 Reply Last reply πŸ‘
                • medeekM
                  medeek
                  Version 2.1.2 - 03.07.2026
                  • Added Weight Callouts as an option for polyline stemwall assemblies.
                  • Added Weight Callouts as an option for stemwall step assemblies.
                  For this detailed breakdown you need to have the "separate callouts" and "weight callouts" both enabled.
                  design.medeek.com
                  • medeekM
                    medeek
                    Version 2.1.3 - 03.15.2026 thru 03.16.2026
                    • Created the Medeek Foundation API.
                    • Enabled the following methods within the Medeek Wall API: sog_draw, validate_medeeksog, sog_move, sog_regen, sog_read_attributes, sog_read_attribute, sog_set_attribute
                    • Added the Medeek Wall API Documentation page to the website.
                    • Added the Medeek Foundation API - Slab-on-Grade Attribute Library Index page to the website.
                    Medeek Foundation API Documentation
                    (design.medeek.com)
                    (design.medeek.com)
                    design.medeek.com
                    • medeekM
                      medeek
                      Version 2.1.4 - 04.13.2026
                      • Enabled quantity 4 and 5 bars of footing rebar for strip footings.
                      design.medeek.com
                      • medeekM
                        medeek
                        Version 2.1.5 - 07.20.2026
                        • Added a SOG "profile" edit tool within the context menu for polygon slab-on-grade assemblies.
                        • Added a "Grid Snap" option with hotkey (End key) into the SOG profile edit tool.
                        design.medeek.com
                        • 19
                        • 20
                        • 21
                        • 22
                        • 23
                        • 23 / 23
