    SOLVED: Replacing image texture without upsetting mapping
    23 Posts 9 Posters 10.3k Views 9 Watching
    • fredo6F Offline
      fredo6
      There is a similar function in ThruPaint...
      • P Offline
        PapcioKris
        EZ solution here. NO PLUGINS
        1. Map your OBJECT1 with MAP1
        2. Open another instance of SU
        3. Copy & paste your OBJECT1 to SU2 (It is mapped correctly)
        4. Replace MAP1 with MAP2 (only texture) in SU1
        5. Copy & paste your OBJECT1 From SU1 to SU2
        6. BAM! You have OBJECT2 in SU2 with MAP2
        You might want to rename your materials after all.
        • N Offline
          nlipovac
          I see it says it is Solved but here is my use of SketchUV Save and Load UV feature.
          SketchUV
          • 2 / 2
