    โš ๏ธ Important | Libfredo 15.6b introduces important bugfixes for Fredo's Extensions Update
    How to rotate better
    Scheduled Pinned Locked Moved Animator Beta
    renderpluginsextensions
    31 Posts 6 Posters 14.7k Views 6 Watching
      Missing this one: I will study that! โ˜€
        driven
        @ntxdave said:
        ...the problem with the garage door (look back at image) is the relationship of the size of the panel versus the size of the arch.
        the animation logic is the same for any size slat...
        click to gif...
        slat longer then arc segment...
        translation + rotation from the same base point for each segment...
        john
          About layers! โ˜€
          But the new visual effect "on-Off" for layers, would make it more intuitive, because each one becomes independent from where it is positioned in the timeline and thus can be reused.
          So wait and see for no headaches! ๐Ÿ˜Ž
            This is one thing! Have you made that with Animator ?
            If yes that must be painful if there not a trick!
            The other is the following objects between them! ๐Ÿ˜„
            • chriC Offline
              chri
              Animate with GEOGEBRA soft
              Chri
                That is this sort of result wanted! ๐Ÿ˜„
                • ntxdaveN Offline
                  ntxdave
                  Yes, it is. The only problem is that if you look at the arch of the track for the garage door, the arc is smaller. Otherwise, it is exactly what I was shooting for.
                  Good work Chri........ ๐Ÿ‘
                  Now if you could just get it to work that way with Animator.
                    It's the Hell to make that one by one ๐Ÿ‘ฟ
                    and you have all luck to make imprecise moves
                    and some deviations like me! ๐Ÿ’š
                    Input attemps some adjusment (rotation, translation) are not easy!
                    Tiredness coming! ๐Ÿ˜ณ
                    Colors at the start ribbons don't stay on them ?
                    You must reput them !
                    hell.skp
                    • fredo6F Offline
                      fredo6
                      That's why it's better to wait for the function to be implemented in Animator!
                        ๐Ÿ‘
                        I can't imagine how will be you brain storming for code all that! ๐Ÿ˜ฎ
                        Bon courage! ๐Ÿ˜Ž
                        • chriC Offline
                          chri
                          Fredo
                          YES (in french) ๐Ÿ’š
                          Congratulations PILOU, great job (I like the name of your file) โ˜€
                          Dave will surely be very happy.
                          Bravo PILOU , beau boulot ( j'aime bien le nom de ton fichier ) โ˜€
                          Dave va surement รชtre trรจs content !
                          Chri
                          • 2 / 2
