    How to setting color by layer shorrtcut
    3 Posts 2 Posters 520 Views 2 Watching
    • L
      lhj_6649
      how to setting color by layer shorrtcut??
      i look shortcut but no exist... how to do??
      i used layer tools ruby but this ruby shortcut is too no exist.. and layer panel is no...
      help me!! πŸ˜†
      • TIGT
        Why not make two Styles - one with Color by Layer set and the other with Color by Material set.
        Set up two Scene Tabs, each using one of those Styles.
        You can remove all other changeable properties from each of those Tabs, so that only the 'Coloring' changes with the Tab.
        Then simply toggling between the two Tabs changes the 'Coloring'.
        • L
          lhj_6649
          thank you~ !
          this ways is more than speed my work πŸ˜›
