    2 tone color fade
    renderpluginsextensions
    7 Posts 4 Posters 2.2k Views 4 Watching
    • P Offline
      Philw
      is there a way to do this type of color fade in VRay for sketchUp?
      I have 2 vray VSF Car colors I want to use, but I have not found a way to mix the 2 to get this type of fade between the 2 to get this type of result.
      (Image from Google)
      • pbacotP Offline
        Don't you need to create a single texture that has the colors and the blend?
        • P Offline
          Philw
          Thought about that but it would just be colors.
          It would not have the "Flake specular" car finish I am looking for. I know in Max I can mix 2 maps and blend the transition between the 2. I have the car finish maps for VRay that some one set up and I am wondering if there is a feature like this in Vray for Sketchup where i can mix maps, so far I have not found this feature in this program.
          • P Offline
            Philw
            Ok this is what I am looking to do and what got me on this quest to find the solution in VRay for Sketchup.
            I have other personal project I am working on that this would be helpful on.
            My 3D model so far
            The Colors I want to mix and control
            • sdmitchS Offline
              sdmitch
              Given the RGB of the two colors, you can generate a color gradient using the following code
              mod = Sketchup.active_model
              sel = mod.selection
              clr1 = Sketchup;;Color.new [162,63,42]#change rgb to match first color
              clr2 = Sketchup;;Color.new [198,184,51]#change rgb to match second color
              faces=sel.grep(Sketchup;;Face).sort{|a,b|a.bounds.center.x<=>b.bounds.center.x}
              faces.each_with_index{|f,i|
                clr3 = clr1.blend clr2,1.0-i.to_f/(faces.length-1).to_f
                f.back_material=f.material=clr3
              http://sdmitch.blogspot.com/
              • P Offline
                Philw
                I will check this out over the weekend.
                Thank you
                  Cool! β˜€
