Animator and Twilight
I just saw a post in a thread on the Twilight forum that said they (Chris was the poster) had reached out to Fredo and would be pursuing the ability to use Animator with Twilight.
@ Dave!
Thanks for the explanation!
Animator works like a charm with Twillight Pro!
Just like you said me - In Animator : Press the icon "Generate a video for the Film"
When the dialog box comes up, you will see an icon to use Twilight Render!
Result will be in th folder Animator videos
Here is a render of a car wash building done with Animator beta v1.1b and Twilight Render Pro version2.6.2.
I used the new tool to smooth out orbiting of the model using the new circular camera path (curved) in the latest version of Animator. I also used the latest version of Twilight Render Pro.
Yes, there are several things that are wrong with the model but this was a test of make sure I could get closer to where I want to go. I am will be working on a cleaner and better version of the model but wanted to let people see how you can use these two tools together. Just in cause you are interested, this particular render took 15:00:07.
Register LoginAdvertisement
