    Vray for sketchup shadow and sharpness
    renderpluginsextensions
    2 Posts 2 Posters 1.3k Views 2 Watching
    • E Offline
      esjaye
      Hey ive just completed a new scene recently, attached herewith are the reference image and the rendered image. Please help me in modifying the settings to get a better render result in the following areas :-
      1. Shadow.
      2. Sky.
      3. Crisp and clarity.
      4. Sharpness.
      Regards.
      Reference image
      Rendered image
      • P Offline
        peerman
        First, I don't see a sun? Use the standard vray environment instead of an hdri to begin with. In your sketchup window make sure the sun/shadows are positioned like you want it to render. Also make your glass more transparent to let more light in (or even remove if you don't need reflections). This will brighten things up. If you succeeded please post the results.
        Regards,
        iMac i7 4,2GHz, 32GB RAM, OS X 10.13.5, Sketchup 2018 Pro, ArchiCAD 21, V-Ray 3.6
