    Need help with specific dimension plugin
    11 Posts 5 Posters 1.7k Views 5 Watching
    • K
      Ka6a
      Hi all.
      I'm not a Ruby programmer and having a headache with one simple question:
      Is it possible to create a plugin for making numbers of dimensions instead measurements?
      For examle: D1, D2, D3... etc
      Asking for help.
      Thanks in advance
      • TIGT
        First add the dimension initially:
        http://www.sketchup.com/intl/en/developer/docs/ourdoc/entities#add_dimension_linear
        Or to modify an existing dim:
        http://www.sketchup.com/intl/en/developer/docs/ourdoc/dimensionlinear
        Then use:
        http://www.sketchup.com/intl/en/developer/docs/ourdoc/dimension#text=
        to edit what that dim's text actually says...
        • G
          Garry K
          You can also do this with your text override.
          dim.text = "D1\n<>"
          \n = means newline and puts the dimension on a second line
          <> = means include the model's units in with the dimension
            I like that tip Garry!
            • K
              Ka6a
              Thank you guys for replying
              So, after titanic labour I have produced this:
              require 'sketchup.rb'
              SKETCHUP_CONSOLE.show
              UI.menu("Plugins").add_item("DimPlugin") {addim}
              def addim
                entities = Sketchup.active_model.entities
                dim = entities.add_dimension_linear [50, 10, 0], [100, 10, 0], [0, 20, 0]
               dim.text = "D1"
              And questions:
              1. How can I choose points for a new dimension (like basic sketchup tool "Dimension" does)?
              2. How can I create multiple dimensions (D1, D2, D3... etc)?
              Thanks again...
              • D
                driven
                dimension first then try
                dims = Sketchup.active_model.entities.grep(Sketchup;;Dimension)
                i = 0
                dims.each do |d|
                i+=1
                d.text = "D#{i}"
                it hard to do a sort, but maybe the order of dimensioning will be honoured...
                john
                • K
                  Ka6a
                  Thank you! It works much better!
                  But I still need a way to pick two dimension's points.
                  Or another decision (if it easier):
                  I could make dimensions by default Sketchup tool, but then I would to replace all of them by my plugin.
                  • TIGT
                    You need to make a "Tool" in Ruby code.
                    This then allows you to pick two or three points etc.
                    http://www.sketchup.com/intl/en/developer/docs/ourdoc/tool
                    Look at the code in my 2dTools to make a Rectangle.
                    Points 1 and 2 would be the dimension start and end and point 3 could set the offset etc.
                    Obviously you don't use the add_line() method, you need this:
                    • K
                      Ka6a
                      Thanks for advice, TIG, but I already tried it... It's too hard code for my low programming skill.
                      Could you answer me:
                      Where can I find sketchup dimension tool code for try to edit it? (Is it possible?)
                      Or how could I solve my problem another way (maybe by replacing text in existing dimensions)?
                      My current "frankenstein"-code 😕 :
                      def addim
                      i = 0
                      dims.each do |d|
                      i+=1
                      d.text = "D#{i}"
                      Thanks again
                      • TIGT
                        You can't do much with native tools, except activate them using Sketchup.send_action()
                        To mimic the native tools you must use the Ruby API.
                        There are many methods.
                        Using the methods I suggested would allow you to make a tool of your own which placed dimensions by picking points etc...
                        @driven already gave you a way of editing existing dimensions' text...
                        http://sketchucation.com/forums/viewtopic.php?p=594206#p594206
                        It is applied to all available dimensions in the model, or could be adjusted to process just the selected ones...
                        • K
                          Ka6a
                          Oh, my! It works! Thank you guys so so much!
                          TIG you are a Ruby wizard! Thank you for your patience
                          So, here is my final result:
