    Need help with specific dimension plugin
    11 Posts 5 Posters 1.6k Views 5 Watching
      Ka6a
      Hi all.
      I'm not a Ruby programmer and having a headache with one simple question:
      Is it possible to create a plugin for making numbers of dimensions instead measurements?
      For examle: D1, D2, D3... etc
      Asking for help.
      Thanks in advance
        First add the dimension initially:
        http://www.sketchup.com/intl/en/developer/docs/ourdoc/entities#add_dimension_linear
        Or to modify an existing dim:
        http://www.sketchup.com/intl/en/developer/docs/ourdoc/dimensionlinear
        Then use:
        http://www.sketchup.com/intl/en/developer/docs/ourdoc/dimension#text=
        to edit what that dim's text actually says...
          Garry K
          You can also do this with your text override.
          dim.text = "D1\n<>"
          \n = means newline and puts the dimension on a second line
          <> = means include the model's units in with the dimension
            I like that tip Garry!
              Ka6a
              Thank you guys for replying
              So, after titanic labour I have produced this:
              require 'sketchup.rb'
              SKETCHUP_CONSOLE.show
              UI.menu("Plugins").add_item("DimPlugin") {addim}
              def addim
                entities = Sketchup.active_model.entities
                dim = entities.add_dimension_linear [50, 10, 0], [100, 10, 0], [0, 20, 0]
               dim.text = "D1"
              And questions:
              1. How can I choose points for a new dimension (like basic sketchup tool "Dimension" does)?
              2. How can I create multiple dimensions (D1, D2, D3... etc)?
              Thanks again...
                driven
                dimension first then try
                dims = Sketchup.active_model.entities.grep(Sketchup;;Dimension)
                i = 0
                dims.each do |d|
                i+=1
                d.text = "D#{i}"
                it hard to do a sort, but maybe the order of dimensioning will be honoured...
                  Ka6a
                  Thank you! It works much better!
                  But I still need a way to pick two dimension's points.
                  Or another decision (if it easier):
                  I could make dimensions by default Sketchup tool, but then I would to replace all of them by my plugin.
                    You need to make a "Tool" in Ruby code.
                    This then allows you to pick two or three points etc.
                    http://www.sketchup.com/intl/en/developer/docs/ourdoc/tool
                    Look at the code in my 2dTools to make a Rectangle.
                    Points 1 and 2 would be the dimension start and end and point 3 could set the offset etc.
                    Obviously you don't use the add_line() method, you need this:
                      Ka6a
                      Thanks for advice, TIG, but I already tried it... It's too hard code for my low programming skill.
                      Could you answer me:
                      Where can I find sketchup dimension tool code for try to edit it? (Is it possible?)
                      Or how could I solve my problem another way (maybe by replacing text in existing dimensions)?
                      My current "frankenstein"-code 😕 :
                      def addim
                      i = 0
                      dims.each do |d|
                      i+=1
                      d.text = "D#{i}"
                      Thanks again
                        You can't do much with native tools, except activate them using Sketchup.send_action()
                        To mimic the native tools you must use the Ruby API.
                        There are many methods.
                        Using the methods I suggested would allow you to make a tool of your own which placed dimensions by picking points etc...
                        @driven already gave you a way of editing existing dimensions' text...
                        http://sketchucation.com/forums/viewtopic.php?p=594206#p594206
                        It is applied to all available dimensions in the model, or could be adjusted to process just the selected ones...
                          Ka6a
                          Oh, my! It works! Thank you guys so so much!
                          TIG you are a Ruby wizard! Thank you for your patience
                          So, here is my final result:
