    File Paths
    3 Posts 2 Posters 537 Views 2 Watching
    • Joe WoodJ Offline
      Joe Wood
      When I open 2016 I get a mssg about the prefered file location paths being wrong,
      what should the file location paths be??
      Joe Wood
      woodsshop.com/
        Your Models, Components, Materials, Styles, Texture-Images, Watermark-Images folder paths should each be set to a separate subfolder within a path of your choosing - typically those might be within:
        C:/Users/Joe/Documents/...
        You'll need to make those folders and add any SKPs, SKMs, Styles, Images into those...
        The ' Export' folder is a similar choice - although perhaps you might prefer:
        C:/Users/Joe/Desktop
        Your default ' Classifications' folder should normally be left as the default - i.e.
        C:/Users/Joe/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/...
        i.e. it's auto-created within the same path as your default ' ../Plugins' folder...
        • Joe WoodJ Offline
          Joe Wood
          Geeze why does this have to be so complicated? I'm lost,
          does it hurt to just leave it all as is, with wrong file paths? As long as I can draw and export images it's OK with me.
          Joe Wood
          woodsshop.com/
