    [Plugin] Animator - v4.6a - 18 Dec 25
    Scheduled Pinned Locked Moved Animator Beta
    renderpluginsextensions
    602 Posts 120 Posters 2.3m Views 120 Watching
    • SchuppeS
      Schuppe
      Hi Fredo
      WOW, more than i dreamed of !!! I will go into this the next days.
      Thanks a lot for your work, great!!! merci beaucoup, tu es le meilleur !!
      I know its silly but it feels like christmas, lol
      Schuppe
      • A
        Ahmed0007
        • OxerO
          Oxer
          Hi Fredo, I created the Spanish language file for Animator v2.0a, here the file:
          http://www.oxervision.blogspot.com/
          • jgbJ
            jgb
            Fredo
            Is there any chance you could come up with a 32bit Animator version? I have SU 2015 32 bit and I cannot upgrade my system to 64 bit O/S (Win 10). The h/w IS 64bit, my Win 10 was mistakenly upgraded to 32bit.
            Even if a few features are disabled, it would be better than nothing.
            jgb
            • N
              nisel
              In the new version, i see some inverse kinematic buttons. Fredo could you add some inverse kinematic tutorials. For example a robotic arm?
              • fredo6F
                fredo6
                @jgb said:
                Fredo
                Unfortunately, I now release Animator for SU2016 and above, because of the support of hi-res screens and also because Animator should become a paid plugin when it has the required amount of features.
                Fredo
                • W
                  whiterabbit
                  The new interface is much nicer ! and the ability to continue on same object with "save next button".
                  Not sure if I have to redo the ffmpeg with the new release, as the video output functions do not show up anymore?
                  • fredo6F
                    fredo6
                    Strange. The file ffmpeg.exe must simply be located in the Sketchup Plugin directory. So, it's independent from the releases of Animator.
                    Fredo
                    • W
                      whiterabbit
                      Sorry for any confusion, I can see the video creation through animator itself, but previously (under recommendation) I was doing it through Thea Render. It is when checking fredo animator in Thea then clicking create animation that the video option no longer exists...maybe that's how it was before?
                      • fredo6F
                        fredo6
                        Strange....
                        I still have it
                        Fredo
                        • W
                          whiterabbit
                          Copy that. I have that option showing up in the Thea panel. See attached gif. It's at the generate video that the only option is an image sequence. I thought previously this would generate a video, or was it always only an image sequence? I can easily stich an image sequence together but was curious if there was a video option...or did I just imagine it?
                          • fredo6F
                            fredo6
                            [attachment=0:13ky44ub]<!-- ia0 -->animator.gif<!-- ia0 -->[/attachment:13ky44ub]
                            Your are right. It seems that Thea only generates a sequence of images.
                            I must say that I never used the generation from Thea and thus did not notice.
                            Fredo
                            • fredo6F
                              fredo6
                              @whiterabbit said:
                              I'm glad we got to the bottom of it ! Thanks for your help. It's an amazing piece of work it should definitely be a paid plugin![flash 640,480:2qtuw4ba][/flash:2qtuw4ba]
                              [attachment=0:2qtuw4ba]<!-- ia0 -->Who cut the cheese.swf<!-- ia0 -->[/attachment:2qtuw4ba]
                              Well...it's going to be a paid plugin actually (with an evaluation version). Just need to have the right amount of features and also a sufficient quality to justify the cost.
                              Fredo
                              PS: by the way, better post a .MOV or a .gif. It's usually diffciult to do anything with SWF files.
                              • W
                                whiterabbit
                                • W
                                  whiterabbit
                                  I only used the swf as the interface looks like that's what it prefers.
                                  • fredo6F
                                    fredo6
                                    New Release: Animator - v2.1a - 20 May 18
                                    Requirement: LibFredo6 v8.4a
                                    Major release
                                    Added Movement Apparition, allowing to make object progressively appear or disappear, based on section planes.
                                    Note: hose models by Eneroth3
                                    If you install LibFredo6 v8.4c, you have the option to use section planes for partial apparition, between 2 boundaries
                                    See plugin home page of Animator for Download of RBZ from the PluginStore.
                                    See Main Post of the Animator thread for more information.
                                    • J
                                      junphuc17945
                                      in version 2.1, i cant generate video
                                      • fredo6F
                                        fredo6
                                        Small bug coming from LibFredo6.
                                        Fixed in LibFredo6 v8.4f, just published.
                                        Fredo
                                        • fredo6F
                                          fredo6
                                          New Release: Animator - v2.2a - 13 July 18
                                          Requirement: LibFredo6 v8.5a
                                          Minor release
                                          • Extension of validity
                                          • Prompt for sequence names can now be configured from the Default Parameter Dialog box. If you set at NO PROMPT, then a default name will be used. You can change it later.
                                          • Note also that there is fast way to insert the current view camera in the timeline, by clicking on the small button in the Insert palette.
                                          • fredo6F
                                            fredo6
                                            New Release: Animator - v2.2b - 14 July 18
                                            Requirement: LibFredo6 v8.5b
                                            Minor release
                                            Full screen option: All Sketchup toolbars, native and extensions are automatically hidden when starting Animator. They are restored in their original position when exiting Animator, either temporarily or fully.
                                            This option can be activated in the Default Parameters dialog box.
                                            The idea is indeed to give you more space on the screen when designing animations.
                                            Here is a short video illustrating the Full Screen option.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 30
                                            • 31
                                            • 13 / 31
