    Cutlist question
    5 Posts 3 Posters 572 Views 3 Watching
      Daddywoofdawg
      I have installed cut list,and I'm wondering,does it only do sheet goods or can I somehow use boards which is what I want?or is there another program like cut-list that I can do boards?
        It splits the parts in to wood, sheet materials or other parts depending upon key words you add to the component names. See this. It's old but it's still applicable.
          slbaumgartner
          On the most recent version, there is a dialog to set up the thicknesses, widths, and lengths of boards you want used as stock for cutting layout. I don't use any of the cutting layout features myself because they don't allow for grain direction, figure matching, or for dealing with flaws in the wood.
            True. There is the layout feature which I covered in the link, too, but I don't find it useful for solid wood, either, because it can't account for flaws in the wood or grain direction. But the text portion is very useful if you need a cut list. I also find it useful as a quick check for problem dimensions.
              slbaumgartner
              I agree completely on both points. The printed parts list is my go-to to take to the lumber yard when selecting boards. And I embarrassingly often discover parts that were drawn just a bit out of whack when their dimensions come out on the printed cutlist with the dread ~.
