    CPoint move rotate name visible in Outliner?
    3 Posts 2 Posters 691 Views 2 Watching
    • deaneauD
      deaneau
      yes this sound curious
      however i would use cpoints like in 3dsMax without using Max.
      cPoints will visible in max
      this points have a special function in some 3d games as attacement point.
      1. the name of this attachement point tell the game what kind of point is this and what kind of objects i can attache
      2. the orientation tell the game what direction have light, objects etc
      this is actually only possible in Max.
      what can i do with this points ? the picture will show this.
      and now i can move and rotate this point.
      this would be great in sketchup.
      if this is
      visible in outliner
      and i can name, rotate and move this point.
      what i have try.
      i have try to group this point. however grouups and point are different kind of "objects" in Max.
      MADE, BORN AND LIVING IN BERLIN
      Big Thank You to all Programmers
      Some German words are so long that they have a perspective. M.Twain
      • TIGT
        You need to make a component or a group for it to show up in the Outliner.
        You can't use cpoints, because these are not persistent - a user can Delete Guides and they are gone out of the 'instance', even when nested inside a definition.
        You could invent a special component with geometry in it, and use special plugin code to somehow mimic some of the functions you hope for - perhaps using naming or attributes etc.
        However, it'd be very very convoluted...
        I can't even think how to start it off, although I suspect it would be possible to achieve something, but given a truly gargantuan effort...
        • deaneauD
          deaneau
          yes TIG actually i draw a rectangle and group this. than i go in the group and ad center point (smustard). after this i must explode the gorup and must delete the rectangle.
          a second way is to draw short help lines in the group to see the point.
          the point alone in the group isnt pickable.
          if i cant name this point or make visible in the outliner i must go the way via Max πŸ˜•
          this was my fear.
          thank you TIG
