    MSPhysics tests and questions
    104 Posts 21 Posters 52.7k Views 21 Watching
    • F Offline
      faust07
      Thanks, Anton! This is a great piece of plugin!
      • N Offline
        nlipovac
        ๐Ÿ˜ฎ ๐Ÿ˜ฎ ๐Ÿ˜ฎ
        • F Offline
          faust07
          I could not resist to render a new desktop background picture for my PC ...
          MSPhysics, indigo RT (path tracing, 7 minutes), removal of the fire flies with image editor.
          SketchUp model
          relevant physics geometry
          SketchUp materials
          rendering indigo RT
            Happy Feet! ๐Ÿ˜Ž
            • F Offline
              faust07
              Test model as an example for large replay data stored in the MSPhysics 0.9.2 separate replay file.
              The data are produced with onTouch and transforming various emitters to the touch points.
              This principle is useful for other physics applications: tire tracks, landslides etc.
              The advantage over the Particle effect is, that you can render it.
              Please let the simulation run till frame 500 or longer, save Replay, exit the model, load it again and test what happens.
              file without birds and sharks
              pure SketchUp
              the target
              • F Offline
                faust07
                Anton, here a long time me nagging question:
                How can I prevent that usually at the beginning of a simulation, transmitted Thruster objects rather accidentally fly into the air at an increased rate?
                This initial speed exceeds the set Thruster impulse by several times and can lead to problems with the viewport.
                Properties of the initial object are: non collidable, collision shape: Null, Thruster Controller: 30, Lock to Body Axis, Mass: 0.015
                Also setting the non-collision per script at the start does not work (onStart { this.collidable=(false) }).
                What is the reason for and what can I do to avoid this?
                Thanks in advance!
                Thruster on start of simulation
                randomly another start
                  markahon
                  How can I use joints or some other way to combine two or more groups/components to form a stiff structure so, that each will have different weight/density and the combined object's center of mass is correct?
                  My specific problem is that I'm designing a table that has wooden tabletop and steel legs. I'm testing different kinds of steel structures as the legs. Then I'm placing weights on the edges of the table to get some kind of an idea what weight would cause the table to tip over and modify the legs' positioning if needed.
                  I tried different kinds of joints, but they all seem to make the table to stand no matter what kind of weight I put on the table edge. The only way working so far for me is to use no joints at all, make the whole table a single component and set approximate weight that I calculate myself. But that will cause the center of mass to be incorrect and afaik affects the results of this simulation somwhat.
                  Any help is much appriecated, thanks!
                    markahon
                    Edit: Duplicate post, see my question in next post.
                    • F Offline
                      faust07
                      Please post your model (reduced, without textures, scenes, stiles etc.) and we will find a solution.
                        markahon
                        Thanks for the reply faust07. Here's one of my designs, reduced, I hope ๐Ÿ˜„ Table design to test what weights cause table to tip over
                        • F Offline
                          faust07
                          In this case it seems to be the right approach to take all the parts into a component.
                          Joints are possible but not very helpful here. (You could test it with the "Fixed" Joint)
                          What I've changed:
                          Table legs and feet broken down into individual subcomponents. Then the collision geometry is more accurate. You can see it if you activate Collision Wireframe in Debug Draw in the MSPhysics UI.
                          The base plate I have assigned the material Concrete and I have the axis position of the cube weights corrected in order to prevent that the parts sink into the ground.
                          The axes were far outside the cube. But I do not know whether this significantly affect the behaviour of the body.
                          The best way to prevent sinking is to increase the value for the material thickness (to 0.10) in the UI. Please test it.
                          table with little corrections
                          • F Offline
                            faust07
                            Hi Anton, short question: how can I make up for the differences between controller and scripted input? With the same pre-set parameters why arise the differences in the results?
                            Model slightly reduced to test it.
                            Pengu-Test_03.skp
                            • F Offline
                              faust07
                              Here is an approximation of the setting of a servo joint (oscillator) with controller or script.
                              The oscillation about 180ยฐ in both directions corresponds to the number pi in the script. Seems somehow to be logical ...
                              Servo-Test_04.skp
                                Anton_S
                                Hello faust,
                                Nice coding there. So, when you assign value via script, i.e some_servo.controller=, the value is assumed as some angle in radians. Whenever, you assign it via controller, the angle is assumed as the angle in preset angle units, which are by default in degrees.
                                Now, instead of iterating through all servos to assign their controller, a more reliable way would be to use a variable. Control the variable through script and change servo angle via controller. Here is what I mean:
                                onStart { @p3_head_osc = 30 set_var('wing', 0) } onUpdate { set_var('wing', oscillator(@p3_head_osc) * 30) }
                                Paste this in the controller of a desired servo:
                                get_var('wing')
                                Other than that, I'm amazed by your improvement in scripting. Keep it up!
                                Anton
                                • F Offline
                                  faust07
                                  Thanks Anton! The simple way is the best - I will try it. Here a little pengu fun with my old script solution and "Curvy Piston".
                                  • robintR Offline
                                    robint
                                    Hi All
                                    Not wishing to hijack this OP, but I cant see where to post otherwise
                                    so here goes. Attached is a simple falling block assy to test the validity of accel due to gravity, ie block should fall 9.81m in 1 sec, all thing set right.
                                    What would be nice is to have a script that stopped the sim once the bloack collided with the baseplate. In theory I should be able to read the time taken, no of frames etc on the bottom lhs of the screen, but just now I approximate this by tapping pause on eyeballing the block - not very accurate at all
                                    Iv'e seen there is an "on touch" script with slamming doors but Im still a ruby newbie
                                    Is there a way to stop the sim on block reaching the baseplate?
                                    FYI If I can get this to work for my students, then the next step is to simulate the viscosity experiment using a falling sphere in fluid, but I dont know if SU can simulate viscous fluid yet?
                                    Great stuff on this page, I am truly humbled
                                    Robin
                                    falling block.skp
                                    As one door closes another one slams in your face
                                    • F Offline
                                      faust07
                                      Hi Robint
                                      Put this script into your baseplate (copy the 3 lines, select the plate, open MSP UI, select "Script", paste the lines into the Script window, run MSP):
                                      onTouch { |toucher, position, normal|
                                      MSPhysics::Simulation.reset
                                      and the simulation stops "onTouch".
                                      • robintR Offline
                                        robint
                                        @faust07 said:
                                        Hi Robint
                                        Hi Faust, thanx for the tip, but not quite there yeet
                                        the simulation resets and I lose all the time/frame data at the bottom of screen - which is what I need for this to be useful.
                                        I tried .pause and .stop but they dont exist
                                        Is there something else I could try?
                                        • robintR Offline
                                          robint
                                          Hi Faust
                                          Through the Ruby Code editor, I found a start_timer and stop_timer function
                                          Would this help?
                                          Say put start at the top to activate when staring sim,
                                          then stop_timer after the reset action line
                                          then display timer?
                                          sorry my newbie attempts at script (do you hav any recommendations on the best way to learn script for MSP - there's so much flack out there its hard to know where to start)
                                          Cheers
                                          Robin
                                          • F Offline
                                            faust07
                                            Hi Robin,
                                            have tested to find a solution to pause simulation per script, but have nothing found until now.
                                            I'm a script newbie too. For my purposes I look into scripts of models from the experts at 3D-Warehouse (AntonS & PituPhysics) or ask them in Anton's main MSP post.
                                            • 6
                                            • 2 / 6
