    MSPhysics tests and questions
    104 Posts 21 Posters 50.5k Views 21 Watching
      markahon
      Thanks for the reply faust07. Here's one of my designs, reduced, I hope πŸ˜„ Table design to test what weights cause table to tip over
      • F Offline
        faust07
        In this case it seems to be the right approach to take all the parts into a component.
        Joints are possible but not very helpful here. (You could test it with the "Fixed" Joint)
        What I've changed:
        Table legs and feet broken down into individual subcomponents. Then the collision geometry is more accurate. You can see it if you activate Collision Wireframe in Debug Draw in the MSPhysics UI.
        The base plate I have assigned the material Concrete and I have the axis position of the cube weights corrected in order to prevent that the parts sink into the ground.
        The axes were far outside the cube. But I do not know whether this significantly affect the behaviour of the body.
        The best way to prevent sinking is to increase the value for the material thickness (to 0.10) in the UI. Please test it.
        table with little corrections
        • F Offline
          faust07
          Hi Anton, short question: how can I make up for the differences between controller and scripted input? With the same pre-set parameters why arise the differences in the results?
          Model slightly reduced to test it.
          Pengu-Test_03.skp
          • F Offline
            faust07
            Here is an approximation of the setting of a servo joint (oscillator) with controller or script.
            The oscillation about 180Β° in both directions corresponds to the number pi in the script. Seems somehow to be logical ...
            Servo-Test_04.skp
              Anton_S
              Hello faust,
              Nice coding there. So, when you assign value via script, i.e some_servo.controller=, the value is assumed as some angle in radians. Whenever, you assign it via controller, the angle is assumed as the angle in preset angle units, which are by default in degrees.
              Now, instead of iterating through all servos to assign their controller, a more reliable way would be to use a variable. Control the variable through script and change servo angle via controller. Here is what I mean:
              onStart { @p3_head_osc = 30 set_var('wing', 0) } onUpdate { set_var('wing', oscillator(@p3_head_osc) * 30) }
              Paste this in the controller of a desired servo:
              get_var('wing')
              Other than that, I'm amazed by your improvement in scripting. Keep it up!
              Anton
              • F Offline
                faust07
                Thanks Anton! The simple way is the best - I will try it. Here a little pengu fun with my old script solution and "Curvy Piston".
                • robintR Offline
                  robint
                  Hi All
                  Not wishing to hijack this OP, but I cant see where to post otherwise
                  so here goes. Attached is a simple falling block assy to test the validity of accel due to gravity, ie block should fall 9.81m in 1 sec, all thing set right.
                  What would be nice is to have a script that stopped the sim once the bloack collided with the baseplate. In theory I should be able to read the time taken, no of frames etc on the bottom lhs of the screen, but just now I approximate this by tapping pause on eyeballing the block - not very accurate at all
                  Iv'e seen there is an "on touch" script with slamming doors but Im still a ruby newbie
                  Is there a way to stop the sim on block reaching the baseplate?
                  FYI If I can get this to work for my students, then the next step is to simulate the viscosity experiment using a falling sphere in fluid, but I dont know if SU can simulate viscous fluid yet?
                  Great stuff on this page, I am truly humbled
                  Robin
                  falling block.skp
                  As one door closes another one slams in your face
                  • F Offline
                    faust07
                    Hi Robint
                    Put this script into your baseplate (copy the 3 lines, select the plate, open MSP UI, select "Script", paste the lines into the Script window, run MSP):
                    onTouch { |toucher, position, normal|
                    MSPhysics::Simulation.reset
                    and the simulation stops "onTouch".
                    • robintR Offline
                      robint
                      @faust07 said:
                      Hi Robint
                      Hi Faust, thanx for the tip, but not quite there yeet
                      the simulation resets and I lose all the time/frame data at the bottom of screen - which is what I need for this to be useful.
                      I tried .pause and .stop but they dont exist
                      Is there something else I could try?
                      • robintR Offline
                        robint
                        Hi Faust
                        Through the Ruby Code editor, I found a start_timer and stop_timer function
                        Would this help?
                        Say put start at the top to activate when staring sim,
                        then stop_timer after the reset action line
                        then display timer?
                        sorry my newbie attempts at script (do you hav any recommendations on the best way to learn script for MSP - there's so much flack out there its hard to know where to start)
                        Cheers
                        Robin
                        • F Offline
                          faust07
                          Hi Robin,
                          have tested to find a solution to pause simulation per script, but have nothing found until now.
                          I'm a script newbie too. For my purposes I look into scripts of models from the experts at 3D-Warehouse (AntonS & PituPhysics) or ask them in Anton's main MSP post.
                          • robintR Offline
                            robint
                            Well we are both struggling, blind leading the blind
                            FYI this timer thing is fundamental to simulating physical systems (mass speed acceleration)
                            The on touch is a good start, just need to time the sequence and display result on reset
                            opens up a whole new way of simulating mechanical systems
                            as fundamental say as a thermometer is to tell you the temperature - if you see my point
                            so I must perservere. If I get a result I will post it you
                            Cheers
                            Robin
                            • robintR Offline
                              robint
                              A bing moment has occured β˜€
                              when I # out the reset line, I just had a ontouch line only and it outputs to screen what might be some sort of final velocity m/s on impact (according to the script info)
                              pls see model
                              Now I cant yet correlate that to the calc velocity which should be 14m/s on impact from 10m
                              it comes out at 58 and varies with the UI sim setting of Newton update rate (currently 10)
                              also from dropping from 5m gives 33 (should be 9.9m/s and is 1/sqr2 - .707) whereas 33/58 is ca.57
                              maybe some dynamic friction in play?
                              Is this a worthwhile line of enquiry?
                              Cheers
                              Robin
                              ps the ball is in anton's examples funny little thing - and something for gamers pool table maybe?
                              falling block.skp
                                Anton_S
                                Yes, the final velocity should be 14 m/s, and it is 14 m/s.
                                Your script in the model you posted, just outputs the frame:
                                onTouch { |toucher, position, normal, force, speed|
                                  simulation.log_line("onTouch #{frame}")
                                That explains why you get unrelated results.
                                To output the final velocity, you should change the code to output the speed:
                                  simulation.log_line("onTouch #{speed}")
                                And besides, setting the linear damping of the falling box to zero will make the final velocity even more right because this will eliminate the dissipative force.
                                • robintR Offline
                                  robint
                                  Thank you so much Anton, I was just about to post an apology for a stoopid boy Pike moment (no smilie for Duh 😳 )
                                  but I read the second line and it outputs frame to screen, what a numpty
                                  You gave me some other scrip that outputs velocity, strange to note that the cube reaches a terminal velocity ca 2m/s ca halfway down - intriguing. Is there something in there that simulates viscosity?
                                  onUpdate {
                                  Get current velocity
                                  cv = this.get_velocity
                                  Output it in the note
                                  note = sprintf("Velocity: (%.3f, %.3f, %.3f)", cv.x, cv.y, cv.z)
                                  simulation.display_note(note)
                                  Cheers
                                  Robin
                                    Anton_S
                                    Yes, the viscosity is simulated by the linear damping. To remove the linear damping, select the desired group, open MSPhysics UI, activate the Properties tab, and set Linear Damping to 0.00. This should alter the height of terminal velocity.
                                    If you meant something else, like water or buoyancy, you can add a buoyancy plane by navigating to (Menu)Extensions->MSPhysics->Create Buoyancy Plane. Although the liquid is not simulated. It's just the buoyancy force that is applied.
                                    • robintR Offline
                                      robint
                                      Hi Anton
                                      Just when I thought you cracked it with speed, something strange happens
                                      When dropping the block from 10m = ok = 14m/s as per calc (see model)
                                      Move the block down to 5m => nonesense answer like 0.07... (should be 9.9m/s)
                                      Yet move block to other elevations like 8.5m or 2.5m , seems to work ok (but I haven't checked the result against calcs (12.9, 7)
                                      So I am completely stumped πŸ˜’
                                      BTW sometimes the block appears to penetrate the baseplate and slowly return to zero, could this be the reason?
                                      Thats ruined my day
                                      Cheers
                                      Robin
                                      falling block2.skp
                                      • robintR Offline
                                        robint
                                        Maybe uncovered a nasty bug? Anton
                                        Here's a suggestion from your speed indicator
                                        onUpdate {
                                        note = sprintf("Velocity: (%.3f)", cv.z)
                                        When it runs, on collision it displays 0.00 as expected, the block has stopped but we lost the terminal velocity
                                        Could we say put an IF loop in the output velocity to note, only iff velocity <say .5m/s, then it should go to zero when the block stops (assuming no bounce)
                                        Just a thought, maybe a simpler approach? from a ruby newby
                                        Cheers
                                        Robin
                                        • robintR Offline
                                          robint
                                          Sorry, Im getting tired
                                          I meant it should retain the highest last value in note when the block stops
                                          Apologies
                                          Robin
                                            Anton_S
                                            It's all cool πŸ˜„
                                            Here is the code for viewing maximum velocity.
                                            onStart {
                                              @max_vz = 0
                                            onUpdate {
                                              if v.z.abs > @max_vz
                                                @max_vz = v.z.abs
                                                simulation.display_note(sprintf("Max Speed %.3f m/s", @max_vz))
                                            And yes, the speed indicator in onTouch may not always work right, which is the problem of the physics engine that my wrapper is using.
                                            • 2 / 6
