    MSPhysics tests and questions
    104 Posts 21 Posters 52.6k Views 21 Watching
    • F Offline
      faust07
      Shark body contact - and a little bit of water splashes.
      I slowly reach my desired results through MSPhysics and small improvements of my scripting capabilities...
      It would be desirable to be able to start the simulation at a specific frame (MS Physics calculates the model until then in "the dark").
      In addition it would be fine if we could save to Replay, export to the renderer and start rendering at the end of the simulation with default settings automatically (in the case of time consuming simulations).
      pure SketchUp output
      rendered with indigo(RT)
        These are amazing! Well done
        • F Offline
          faust07
          Thanks Rich
            We are listening seagulls! ๐Ÿ˜Ž
            • F Offline
              faust07
              Oh yes! Sound is the next step. No problem with MSPhysics...
                Anton_S
                That's a fine piece of rendering, faust!
                • F Offline
                  faust07
                  Thanks, Anton! This is a great piece of plugin!
                  • N Offline
                    nlipovac
                    ๐Ÿ˜ฎ ๐Ÿ˜ฎ ๐Ÿ˜ฎ
                    • F Offline
                      faust07
                      I could not resist to render a new desktop background picture for my PC ...
                      MSPhysics, indigo RT (path tracing, 7 minutes), removal of the fire flies with image editor.
                      SketchUp model
                      relevant physics geometry
                      SketchUp materials
                      rendering indigo RT
                        Happy Feet! ๐Ÿ˜Ž
                        • F Offline
                          faust07
                          Test model as an example for large replay data stored in the MSPhysics 0.9.2 separate replay file.
                          The data are produced with onTouch and transforming various emitters to the touch points.
                          This principle is useful for other physics applications: tire tracks, landslides etc.
                          The advantage over the Particle effect is, that you can render it.
                          Please let the simulation run till frame 500 or longer, save Replay, exit the model, load it again and test what happens.
                          file without birds and sharks
                          pure SketchUp
                          the target
                          • F Offline
                            faust07
                            Anton, here a long time me nagging question:
                            How can I prevent that usually at the beginning of a simulation, transmitted Thruster objects rather accidentally fly into the air at an increased rate?
                            This initial speed exceeds the set Thruster impulse by several times and can lead to problems with the viewport.
                            Properties of the initial object are: non collidable, collision shape: Null, Thruster Controller: 30, Lock to Body Axis, Mass: 0.015
                            Also setting the non-collision per script at the start does not work (onStart { this.collidable=(false) }).
                            What is the reason for and what can I do to avoid this?
                            Thanks in advance!
                            Thruster on start of simulation
                            randomly another start
                              markahon
                              How can I use joints or some other way to combine two or more groups/components to form a stiff structure so, that each will have different weight/density and the combined object's center of mass is correct?
                              My specific problem is that I'm designing a table that has wooden tabletop and steel legs. I'm testing different kinds of steel structures as the legs. Then I'm placing weights on the edges of the table to get some kind of an idea what weight would cause the table to tip over and modify the legs' positioning if needed.
                              I tried different kinds of joints, but they all seem to make the table to stand no matter what kind of weight I put on the table edge. The only way working so far for me is to use no joints at all, make the whole table a single component and set approximate weight that I calculate myself. But that will cause the center of mass to be incorrect and afaik affects the results of this simulation somwhat.
                              Any help is much appriecated, thanks!
                                markahon
                                Edit: Duplicate post, see my question in next post.
                                • F Offline
                                  faust07
                                  Please post your model (reduced, without textures, scenes, stiles etc.) and we will find a solution.
                                    markahon
                                    Thanks for the reply faust07. Here's one of my designs, reduced, I hope ๐Ÿ˜„ Table design to test what weights cause table to tip over
                                    • F Offline
                                      faust07
                                      In this case it seems to be the right approach to take all the parts into a component.
                                      Joints are possible but not very helpful here. (You could test it with the "Fixed" Joint)
                                      What I've changed:
                                      Table legs and feet broken down into individual subcomponents. Then the collision geometry is more accurate. You can see it if you activate Collision Wireframe in Debug Draw in the MSPhysics UI.
                                      The base plate I have assigned the material Concrete and I have the axis position of the cube weights corrected in order to prevent that the parts sink into the ground.
                                      The axes were far outside the cube. But I do not know whether this significantly affect the behaviour of the body.
                                      The best way to prevent sinking is to increase the value for the material thickness (to 0.10) in the UI. Please test it.
                                      table with little corrections
                                      • F Offline
                                        faust07
                                        Hi Anton, short question: how can I make up for the differences between controller and scripted input? With the same pre-set parameters why arise the differences in the results?
                                        Model slightly reduced to test it.
                                        Pengu-Test_03.skp
                                        • F Offline
                                          faust07
                                          Here is an approximation of the setting of a servo joint (oscillator) with controller or script.
                                          The oscillation about 180ยฐ in both directions corresponds to the number pi in the script. Seems somehow to be logical ...
                                          Servo-Test_04.skp
                                            Anton_S
                                            Hello faust,
                                            Nice coding there. So, when you assign value via script, i.e some_servo.controller=, the value is assumed as some angle in radians. Whenever, you assign it via controller, the angle is assumed as the angle in preset angle units, which are by default in degrees.
                                            Now, instead of iterating through all servos to assign their controller, a more reliable way would be to use a variable. Control the variable through script and change servo angle via controller. Here is what I mean:
                                            onStart { @p3_head_osc = 30 set_var('wing', 0) } onUpdate { set_var('wing', oscillator(@p3_head_osc) * 30) }
                                            Paste this in the controller of a desired servo:
                                            get_var('wing')
                                            Other than that, I'm amazed by your improvement in scripting. Keep it up!
                                            Anton
                                            • 2 / 6
