    How to have two textures and blend them use alpha
    renderpluginsextensions
    3 Posts 3 Posters 827 Views 3 Watching
    • S
      sketchuh
      I can't figure out how to have two diffuse layers with images as texture and let them show using black and white alpha.
      if i have two diffuse layers, where can i set them to show both of them at the same time?!
      Thanks!!
      • R
        rspierenburg
        I'm guessing you would have to layer the two diffuse layers with the top one having a TexBitmap in the transparency slot.
        • niuanseN
          niuanse
          You have to use TexMix material in the Diffuse slot. Choose Color A slot to load the first texture and Color B slot to load the second texture. Blend them using Color Mix with the alpha texture loaded in Mix map slot. That's it.
