    Cross-platform hardware detection
    12 Posts 4 Posters 1.5k Views 4 Watching
    • bomastudioB
      bomastudio
      On Win I'm using WIN32OLE to get HW info (till now I can get only harddisk datas, I need a good doc reference for WIN32OLE) .....but any cross-platform way to get these infos?
      • D
        driven
        what are you trying to get?
        there are a number of threads about ipconfig/ifconfig to get the MAC address on both PC and mac...
        john
        • bomastudioB
          bomastudio
          I need to get CPU, Network, Harddisk infos
          • TIGT
            Someone else can do the MAC side...
            But on a PC...
            info =systeminfo`` [note the left facing `]
            Will return the system-info in a text format [a lot of info] - so you'll need to 'parse' it...
            It also has an annoying albeit brief black CMD window - you can sidestep this window's appearance by using VB etc...
            This requires some convoluted programming...
            BUT nothing is perfect...
            You might be able to add filtering arguments to get exactly what you want...
            But... you haven't explained what you want to achieve...
            • S
              slbaumgartner
              On Mac, the nearest is probably system_profiler. It takes a while to run and has only limited options to reduce its large volume of output. Just as TIG suggested for the Windows version, you will no doubt need to invest in some post-processing to extract the specific info you want. Depending on what you need, there might be alternatives.
              • bomastudioB
                bomastudio
                I need to retrieve some alpha-numeric code to locate a pc as unique worldwide, so I thought to get serial numbers (physical) of CPU and/or hardisk and/or MAC address...
                • TIGT
                  On a PC you can use win32ole to get this kind of info 'silently' [i.e. without the brief cmd window] thus:
                  def get_macaddr()
                    require 'win32ole'
                    macaddr = false
                    net = WIN32OLE.connect("winmgmts;\\\\.")
                    net.InstancesOf("win32_networkadapterconfiguration").each{|i|
                      if i.ipenabled == false
                        #puts "Interface Disabled"
                      else
                        #puts i.ipaddress
                        #puts i.defaultipgateway
                        puts macaddr = i.macaddress
                    return macaddr
                  This obviously can give you more info than you need, so just take what you want !
                  I've used # here to only process the macaddr...
                  You set a reference for macaddr outside the block and return it after processing - false if failed
                  On a MAC you can use:
                  def get_macaddr()
                    return (%x'ipconfig getpacket en1').split('chaddr = ')[1].split("\n")[0]
                  Also without any annoying terminal-window !
                  Simply test for the OS
                  if RUBY_PLATFORM.downcase =~ /darwin/
                  it's OSX...
                  • S
                    slbaumgartner
                    On a Mac you can use either of these commands to get the MAC address of the default network interface (you will need to parse the line to extract it):
                    ` ifconfig en0 ether
                    networksetup -getmacaddress en0`
                    (in both cases that is a zero not an "oh" in en0)
                    • TIGT
                      Yes... there are many ways...
                      • D
                        driven
                        @steve
                        do you know if networksetup -getmacaddress requires "admin" privileges to run.
                        I asked before [after offering it as an option] in another thread, but never got a definitive answer...
                        john
                        • S
                          slbaumgartner
                          @driven, good question. Since against all advice I usually keep my account at admin, I sometimes forget to check. The man page for networksetup says it requires admin privileges in general and root for setting most things. ifconfig also requires admin for most settings, but I believe any user can run it to query values.
                          • D
                            driven
                            I know variations on ifconfig en0 ether.to_s.split('ether ')[1].strip have proven robust for a few authors...
                            but my question to all of them is why?
                            @bomastudio what is your licensing strategy?
                            you may not need to be so invasive...
                            john
