    Learning to render with Twilight Hobby
    49 Posts 11 Posters 8.8k Views 11 Watching
    • pbacotP Offline
      Dave,
      Did you use a edge overlay in the render? Nice job. I think the metal as he says is nice, because the other metal looks too perfectly reflective to be realistic.
      Peter
      • olisheaO Offline
        olishea
        @pilou said:
        I never made renderings, it's not my cup of thea
        πŸ˜„ πŸ˜„ πŸ˜„
        oli
        • ntxdaveN Offline
          ntxdave
          I appreciate the patience all of you are showing me. I do not understand why I am being so dense. Box, there is a download of things that can be used with Twilight on the Kerkeythea site. I used one of those in this latest renderings using the settings like you suggested. Even with my "box" background, it looks much better. I just need to keep reading and exploring/trying.
          This one is much better (because of your information).
          I did lighten up the blue cloth a little and will go back and lighten the wall a little.
          This is just the medium setting @ 1:06. I am sure the high setting would make it even better.
          Press F1...thank me later
            @ NDave : You will be surprised, I never made renderings, it's not my cup of thea, i just make translations of Render manuals or sites of render's engine, or UI!
            Like these ones for TwillightRender, Visualizer, Podium, LightUp, SimLab etc... ! πŸ˜‰
            For the render above I just read what has said Box and voilΓ ! πŸ˜„
            (the only difference is the apply of a standard Wall/Floor material)
            So you can make the same in Twillight!
            All renders today make quasi all the same things, just difference is the ergonomy!
            I have been using Twilight because it is free.
            Twillight is perfect! 😎
            3 click process is not going well for me
            You right if you are hobbyist prefer the "one Click"! Alas this one is pricey (see KeyShot)
              @pbacot said:
              Dave,
              Peter
              Peter, yes. I did use an overlay. Actually, I pasted a Hidden Line exported onto a separate layer set to Multiply. I made the Hidden Line export at 4k or 5k wide and resized it down to the size of the rendered image so that the lines would be very thin. I also adjusted the opacity of that layer so the lines would be fairly light. All very quick and easy to do.
              @ntxDave, I could have also made the floor reflective but as I said, I was just trying to make a quick example and didn't bother setting up all of the materials.
              • ntxdaveN Offline
                ntxdave
                @box said:
                @ntxdave said:
                What is the sketchucation studion pack?
                Thanks - got it. I am experimenting with each of the backgrounds.....
                • soloS Offline
                  solo
                  Ugh! I just missed a 'render this' challenge. πŸ’š
                  http://www.solos-art.com
                  • ntxdaveN Offline
                    ntxdave
                    Welcome aboard but the real challenge is me learning how to use a rendering engine. ❗
                      db11
                      Dave --
                      Love this look, with the thin line overlay. It's just slightly diagrammatic, which really suits technical / mechanical subjects. And thanks for the mini-tut on how to achieve it!
                      Doug
                        Doug, I'm happy it helped someone. πŸ˜‰
                        • ntxdaveN Offline
                          ntxdave
                          @dave r said:
                          @pbacot said:
                          Dave,
                          Peter
                          What the heck does all of this mean?
                          @Box, I tried all 10 of the backgrounds. Now I am going to try to learn how to use the lights. When I select certain light types (Projector or IES), it asks for an image file (projector) or IES (ies). Is there a source for the light types?
                            Dave, most rendering applications render the faces and not the lines that border the faces. To get the lines dividing the pipe into sections or the blue thing to show as it does, you would need to either create 3D geometry to get small gaps and shadows are you could do what I described.
                            Here's an example of a render I did with no materials. If I hadn't made the hidden line image to overlay, there'd be no separation between the case sides and the legs or the drawer front and draw sides.
                            [url=https://flic.kr/p/Bccrw3]
                            https://farm1.staticflickr.com/727/23099200410_ce3df302ac.jpg
                            You can create that separation with material changes but when the material is the same on either side of the seam, you need to do something different.
                            • ntxdaveN Offline
                              ntxdave
                              Makes sense. I just need to figure out how to do that with Twilight Hobby.
                                This has to be done outside of SketchUp. Export a hidden line image from SU and combine it with the rendered image in an image editor.
                                  Twilight renders in the SketchUp window, correct? It does look like you are getting better with it.
                                  • ntxdaveN Offline
                                    ntxdave
                                    After doing some more "playing around" in Twilight Hobby, I tried some more settings and I think this image has come a long wary from where I started. Dave, you will notice that there are some lines showing the jointed pieces of piping along the right side.
                                    Not perfect by any stretch of the imagination but progress...........this one was done at only medium resolution. Might look even better at high resolution.
                                    Still another angle with same settings
                                    • ntxdaveN Offline
                                      ntxdave
                                      Yes, it has a series of popup windows that allow you to set everything up and render while still in SketchUp.
                                      BTW: I did an edit and showed the equipment from another angle with the same settings.
                                      • ntxdaveN Offline
                                        ntxdave
                                        Latest attempts.....making more progress in understanding how the product works and how to control various parts........
                                        Medium Resolution
                                        Higher Resolution + some changes in walls & floor
                                        • ntxdaveN Offline
                                          ntxdave
                                          Continuing to learn and experiment. Here are 2 more renders of the office and part of the support equipment room for a car wash.
                                          Support Equipment Room
                                          Lobby
                                          These are both section cuts and as you can see, I still have more learning to do. In particular, in the lobby, the chairs are not supposed to be shinny at all and the glass is too dark. In fact the whole office is too dark and yes, I need to have the lamp turned on. But I think I am seeing some progress so it is just a matter of continuing to learn. Good thing these are just for my own fun and I am not using them for any commercial purposes (yes I would then upgrade to the full/pro version}.
                                          In particular, the glass is getting to me. That is why I issued the challenge in this thread http://sketchucation.com/forums/viewtopic.php?f=80%26amp;t=64364
                                            It's coming along. I think you should use Perspective instead of Parallel Projection for the camera setting in your renders. They look strange as they are at least for someone who has binocular vision and sees parallel lines running off to vanishing points.
                                            • 2 / 3
