    Viewer and 3Dconnexion
    6 Posts 4 Posters 802 Views 4 Watching
    • flyer50F Offline
      flyer50
      Hello to everybody
      On Win 7 64 Pro I installed Sketchup 15 without any problems.
      I reinstalled the 3DConnexion wireless mouse that I upgraded to 64-bit, and I have no problems.
      I installed SU Viewer 32 bit but the mouse is not recognized, I tried to install Viewer 64 bit version but still it does not work.
      Also when I enter Viewer program in the list of the predefined programs to open it automatically I receive a system error that says :
      common_application.dll is not present on the PC.
      but I see it in the same directory where viewer.exe is installed .
      I would like to know if it possible to solve the connection of Viewer with the predefined programs and if it is possible to use Viewer with 3Dconnexion mouse.
      thank you very much
      Flyer50
      • BoxB Offline
        Kinda lost, why install viewer which is just a crippled version of SU when you already have SU installed.
        Other than that, I cam tell you my 3dconexion works happily with SU8 to SU16 and viewer on win 7,8 and 10, but different PC's
        • flyer50F Offline
          flyer50
          I would use Viewer because I can watch files quickly without allowing changes.
          Now even on my pc 3Dconnexion works fine with all versions of SU from 8 to 15 but
          the problem is with Viewer (3D mouse only acts as a zoom)
          I do not think it is a limitation of the PC.
          • 3.1 GHz
          • 16 GB
          • Solid state HD.
            Win 7 Pro 64 (for the moment I do not like later versions)
          The installations are in the default directory suggested by the installer.
          Maybe there are remaining settings that conflict but I do not know how to solve
            Charlie__V
            Sounds like you may have a problem with the 3Dxware (3D Connexion Software)
            Since you originally installed 32 bit version of the viewer it could be that 3DConnexion 64 bit failed to recognize it.
            Just a guess though............maybe you could ask on the 3DX forums?
            Or try uninstalling and reinstalling the 64bit version of 3DxWare?
            Charlie
              driven
              3dConnexion uses a SU plugin...
              the SU Viewer doesn't have Ruby, so no plugins will work...
              john
              • flyer50F Offline
                flyer50
                I did not find the plugin directory and I was afraid that it could not work. thank you for the confirmation
                Flyer50
