    Mac and Windows 'New Model' differences...
    17 Posts 4 Posters 2.0k Views 4 Watching
      driven
      I'm looking at ways to optimise some code and have made a couple of methods that both work on a mac...
      however, I had reports from testers that neither work on a PC...
      Is it possible to have either work on a PC?
      the example writes a skp to your Desktop, unless you change the path...
      to run, paste code into RC and hit return...
      then type auto_create and hit return...
      # Test file is 5MB,  first is quicker if selection is empty?...
      def empty_selection
      	new_skp = File.expand_path("~/Desktop/john_test1.skp")
      	begin
               # original stays open and new opens in front [0.14629]
      	  Sketchup.active_model.save_copy(new_skp)
      	rescue # for un-saved original
                # original closes and new opens on mac [1.222455]
      	  Sketchup.active_model.save(new_skp)
              # next is not needed for either save or save_as on mac
              # Sketchup.open_file(new_skp) #with save_copy() original stays open [1.920228]
              # just show the ruby works in the new window...
      	Sketchup.active_model.rendering_options['BackgroundColor'] = 'red'
      # faster than collecting and deleting unwanted entities on large complex models...
      # I have I mac cocoa utility to avoid using .send_action(),
      # but this is a little faster and 'should' be cross platform...
      def with_selection
      	new_skp = File.expand_path("~/Desktop/john_test2.skp")
      	Sketchup.send_action('selectSelectionTool;') # copy needs a trigger on mac for copy to work
      	Sketchup.send_action('copy;')
      	Sketchup.send_action('newDocument;')
      	Sketchup.send_action('pasteInPlace;')
      	sel = Sketchup.active_model.selection
      	view = Sketchup.active_model.active_view
      	view.zoom(sel)
             # original stays open time depends on the selection size...
      	Sketchup.active_model.rendering_options['BackgroundColor'] = 'green'
      def auto_create
      	t1 = Time.now
      	sel.empty? ? empty_selection ; with_selection
      	p time = Time.now - t1
      	UI.messagebox(time)
      when I look at other examples I can't spot what I'm missing...
      john
      • G Offline
        Garry K
        auto_create
        Error: #<NameError: undefined local variable or method sel' for main:Object> <main>:26:in with_selection'
        <main>:36:in auto_create' <main>:in <main>'
        SketchUp:1:in `eval'
          driven
          cheers for testing Garry, I chopped the bit out of a bigger plugin and missed re-defining sel for the new model
          i.e. sel = Sketchup.active_model.selection
          I updated the example code...
          did it produce a model?
          before fixing that, on the mac I get the new skp, then the sel error shows in RC...
          i.e. it doesn't stop the new skp happening...
          john
          • sdmitchS Offline
            sdmitch
            empty_selection works on PC and SU2014.
            with_selection seems to work but not really. Perhaps because I can't find the 'copy:','newDocument:', and 'pasteInPlace:' .send_action options in the API.
            However the 'newDocument:' option must work since I end up with an empty untitled model.
            Also 'sel' needs to be passed to the with_selection method or changed to @sel.
            http://sdmitch.blogspot.com/
              driven
              that's good news, maybe I had another glitch in the full plugin...
              they should all exist, but I may need to use the numeric values on a PC?
              I recall, checking them all for Dan and thought PC's could use either...
              good start...
              you need to re-define sel or the @sel would refer to the original skp not the new one [on mac at least]...
              I did update the code for that, did it still not work?
              thanks for testing...
              john
              • sdmitchS Offline
                sdmitch
                I had already made the 'sel' change in my copy of the code.
                Like before, the file created on the desktop is the same for with_selection and empty_selection. With_selection leaves me with an empty Untitled model.
                I get no errors output to the RC.
                  driven
                  does finding the send actions work the same on a PC?
                  i.e. if I set 'copy' as a Shortcut, and then run Sketchup.get_shortcuts the wording returned can be used as a send_action string?
                  john
                    driven
                    I removed the previous send_action()'s but added in Sketchup.send_action('makeGroup:') which should work on both platforms...
                    on a mac I get this, does it work the same on a PC?
                    # first is quicker if selection is empty?...
                    def empty_selection
                    	begin
                    	  Sketchup.active_model.save_copy(new_skp) # [0.14629]
                    	  Sketchup.active_model.save(new_skp) # original closes [1.222455]
                    # faster than collecting and deleting unwanted items...
                    def with_selection
                    	ins = sel[0].to_component
                    	defn = ins.definition
                    	# named only to check if it's been undone...
                    	defn.name = "Explode Me Later"
                    	defn.save_as(new_skp)
                    	# revert original
                    	3.times {Sketchup.undo}
                    	Sketchup.open_file(new_skp) # original stays open time depends on the selection size...
                    def auto_create
                    	t1 = Time.now
                    	UI.messagebox(time)
                    john
                      Your undocumented:
                      Sketchup.send_action("makeGroup:")
                      doesn't work on [my] PC - BUT:
                      Sketchup.send_action(21182)
                      does work on [my] PC [but of course that doesn't work on MAC !]
                      But if you are working with creating a group from a Selection, then you can use the cross-platform API methods, thus:
                      group = Sketchup.active_model.active_entities.add_group( Sketchup.active_model.selection.to_a ); Sketchup.active_model.selection.add( group )
                      which mimics those other platform specific 'send_actions' on either OS...
                      • G Offline
                        Garry K
                        auto_create
                        0.12499
                        I get a big red screen - that is all
                        My default template is set to mm with a precision of 0.001
                          driven
                          cheers Tig, I may have gotten there eventually...
                          this works on the mac as suggested...
                          do I need to close the original on a PC for the new one to open with geometry and green background?
                          it's driving nuts as every version I've tried runs on a mac, and each one has been faster that the last...
                          def with_selection
                                  group = Sketchup.active_model.active_entities.add_group( sel.to_a )
                                  Sketchup.active_model.selection.add( group ) if sel.length > 0
                          	ins = group.to_component
                          	# revert original
                            # re-define for new skp...
                            driven
                            @Garry, the template shouldn't matter...
                            I just can't figure out why you don't get the geometry...
                            This is just a tiny part of a working mac plugin that I'm now porting to PC...
                            on the mac it can grab 100 mixed items from a 1000 item file and cleanly add them to a new model...
                            one test file took 6 hrs to process and delete the 900 unwanted entities, where this take seconds...
                            john
                              On a PC an instance of SketchUp is opened for separate for each SKP.
                              On a MAC one instance of SketchUp opens all SKPs.
                              So on a PC, if you you use:
                              Sketchup.open_file("C:/users/tig/desktop/a.skp")
                              its opens that SKP file, BUT closes the current one !
                              But you could use:
                              UI.openURL("file:///#{full_path_to_skp}")
                              which, on a PC, will open the specified SKP in a new instance of SketchUp [and it'll probably work on a MAC, but then it'll be using the same SketchUp]...
                                driven
                                @tig said:
                                ...But you could use:
                                it works exactly the same as open_file on a mac...
                                you can pass the new model to the next ruby method...
                                on a PC, I assume a new instance would need manual intervention to carry on to step 2 of any ruby script?
                                Are there ways around that?
                                I'm starting to see why 'component_edit_window' has so many observers...
                                john
                                  driven
                                  @tig said:
                                  So on a PC, if you use:
                                  on re-reading this and it may be all I need...
                                  i.e. opens the new_skp [containing the selection] in the current ruby session...
                                  Is that what happens?
                                  keeping the original open isn't a requirement, in fact I'm wanting to preserve intact, and run my actual tool which is destructive on the copy/sub-set...
                                  john
                                    Yes, opening a second SKP in the same SketchUp preserves the current Ruby settings from the first SKP.
                                    If you open up a second SketchUp, then the first SKP's Ruby set up is potentially in accessible.
                                    Of course, in the first SKP you could write some 'defaults' out to SketchUp [i.e. into the PC Registry], and read those back in, while inside the second SKP, but you then need to load/run some code ?
                                      driven
                                      cheers Tig,
                                      the plugin runs my 'selector' tool after new_skp has been cleaned up...
                                      the 'selector' can be scaled, rotated or moved before running the cuts...
                                      any solids remain solids afterwards...
                                      I need a PC version to attract more testers...
                                      john
