    Mac and Windows 'New Model' differences...
    17 Posts 4 Posters 2.4k Views 4 Watching
      driven
      does finding the send actions work the same on a PC?
      i.e. if I set 'copy' as a Shortcut, and then run Sketchup.get_shortcuts the wording returned can be used as a send_action string?
        driven
        I removed the previous send_action()'s but added in Sketchup.send_action('makeGroup:') which should work on both platforms...
        on a mac I get this, does it work the same on a PC?
        # first is quicker if selection is empty?...
        def empty_selection
        	new_skp = File.expand_path("~/Desktop/john_test1.skp")
        	begin
        	  Sketchup.active_model.save_copy(new_skp) # [0.14629]
        	rescue # for un-saved original
        	  Sketchup.active_model.save(new_skp) # original closes [1.222455]
        	Sketchup.open_file(new_skp) #with save_copy() original stays open [1.920228]
        	Sketchup.active_model.rendering_options['BackgroundColor'] = 'red'
        # faster than collecting and deleting unwanted items...
        def with_selection
        	new_skp = File.expand_path("~/Desktop/john_test2.skp")
         	sel = Sketchup.active_model.selection
        	ins = sel[0].to_component
        	defn = ins.definition
        	# named only to check if it's been undone...
        	defn.name = "Explode Me Later"
        	defn.save_as(new_skp)
        	# revert original
        	3.times {Sketchup.undo}
        	Sketchup.open_file(new_skp) # original stays open time depends on the selection size...
        	Sketchup.active_model.rendering_options['BackgroundColor'] = 'green'
        def auto_create
        	t1 = Time.now
        	sel.empty? ? empty_selection ; with_selection
        	p time = Time.now - t1
        	UI.messagebox(time)
          Your undocumented:
          Sketchup.send_action("makeGroup:")
          doesn't work on [my] PC - BUT:
          Sketchup.send_action(21182)
          does work on [my] PC [but of course that doesn't work on MAC !]
          But if you are working with creating a group from a Selection, then you can use the cross-platform API methods, thus:
          group = Sketchup.active_model.active_entities.add_group( Sketchup.active_model.selection.to_a ); Sketchup.active_model.selection.add( group )
          which mimics those other platform specific 'send_actions' on either OS...
          • G
            Garry K
            auto_create
            0.12499
            I get a big red screen - that is all
            My default template is set to mm with a precision of 0.001
              driven
              cheers Tig, I may have gotten there eventually...
              this works on the mac as suggested...
              do I need to close the original on a PC for the new one to open with geometry and green background?
              it's driving nuts as every version I've tried runs on a mac, and each one has been faster that the last...
              def with_selection
                      group = Sketchup.active_model.active_entities.add_group( sel.to_a )
                      Sketchup.active_model.selection.add( group ) if sel.length > 0
              	ins = group.to_component
              	# revert original
                # re-define for new skp...
                driven
                @Garry, the template shouldn't matter...
                I just can't figure out why you don't get the geometry...
                This is just a tiny part of a working mac plugin that I'm now porting to PC...
                on the mac it can grab 100 mixed items from a 1000 item file and cleanly add them to a new model...
                one test file took 6 hrs to process and delete the 900 unwanted entities, where this take seconds...
                  On a PC an instance of SketchUp is opened for separate for each SKP.
                  On a MAC one instance of SketchUp opens all SKPs.
                  So on a PC, if you you use:
                  Sketchup.open_file("C:/users/tig/desktop/a.skp")
                  its opens that SKP file, BUT closes the current one !
                  But you could use:
                  UI.openURL("file:///#{full_path_to_skp}")
                  which, on a PC, will open the specified SKP in a new instance of SketchUp [and it'll probably work on a MAC, but then it'll be using the same SketchUp]...
                    driven
                    @tig said:
                    ...But you could use:
                    it works exactly the same as open_file on a mac...
                    you can pass the new model to the next ruby method...
                    on a PC, I assume a new instance would need manual intervention to carry on to step 2 of any ruby script?
                    Are there ways around that?
                    I'm starting to see why 'component_edit_window' has so many observers...
                      driven
                      @tig said:
                      So on a PC, if you use:
                      on re-reading this and it may be all I need...
                      i.e. opens the new_skp [containing the selection] in the current ruby session...
                      Is that what happens?
                      keeping the original open isn't a requirement, in fact I'm wanting to preserve intact, and run my actual tool which is destructive on the copy/sub-set...
                        Yes, opening a second SKP in the same SketchUp preserves the current Ruby settings from the first SKP.
                        If you open up a second SketchUp, then the first SKP's Ruby set up is potentially in accessible.
                        Of course, in the first SKP you could write some 'defaults' out to SketchUp [i.e. into the PC Registry], and read those back in, while inside the second SKP, but you then need to load/run some code ?
                          driven
                          cheers Tig,
                          the plugin runs my 'selector' tool after new_skp has been cleaned up...
                          the 'selector' can be scaled, rotated or moved before running the cuts...
                          any solids remain solids afterwards...
                          I need a PC version to attract more testers...
                          With your input, this post could be even better šŸ’—
