    Mac and Windows 'New Model' differences...
    17 Posts 4 Posters 2.4k Views 4 Watching
      driven
      @sdmitch said:
      empty_selection works on PC and SU2014.
      that's good news, maybe I had another glitch in the full plugin...
      with_selection seems to work but not really. Perhaps because I can't find the 'copy:','newDocument:', and 'pasteInPlace:' .send_action options in the API.
      they should all exist, but I may need to use the numeric values on a PC?
      I recall, checking them all for Dan and thought PC's could use either...
      However the 'newDocument:' option must work since I end up with an empty untitled model.
      good start...
      Also 'sel' needs to be passed to the with_selection method or changed to @sel.
      you need to re-define sel or the @sel would refer to the original skp not the new one [on mac at least]...
      I did update the code for that, did it still not work?
      thanks for testing...
      • sdmitchS
        sdmitch
        I had already made the 'sel' change in my copy of the code.
        Like before, the file created on the desktop is the same for with_selection and empty_selection. With_selection leaves me with an empty Untitled model.
        I get no errors output to the RC.
        http://sdmitch.blogspot.com/
          driven
          does finding the send actions work the same on a PC?
          i.e. if I set 'copy' as a Shortcut, and then run Sketchup.get_shortcuts the wording returned can be used as a send_action string?
            driven
            I removed the previous send_action()'s but added in Sketchup.send_action('makeGroup:') which should work on both platforms...
            on a mac I get this, does it work the same on a PC?
            # first is quicker if selection is empty?...
            def empty_selection
            	new_skp = File.expand_path("~/Desktop/john_test1.skp")
            	begin
            	  Sketchup.active_model.save_copy(new_skp) # [0.14629]
            	rescue # for un-saved original
            	  Sketchup.active_model.save(new_skp) # original closes [1.222455]
            	Sketchup.open_file(new_skp) #with save_copy() original stays open [1.920228]
            	Sketchup.active_model.rendering_options['BackgroundColor'] = 'red'
            # faster than collecting and deleting unwanted items...
            def with_selection
            	new_skp = File.expand_path("~/Desktop/john_test2.skp")
             	sel = Sketchup.active_model.selection
            	ins = sel[0].to_component
            	defn = ins.definition
            	# named only to check if it's been undone...
            	defn.name = "Explode Me Later"
            	defn.save_as(new_skp)
            	# revert original
            	3.times {Sketchup.undo}
            	Sketchup.open_file(new_skp) # original stays open time depends on the selection size...
            	Sketchup.active_model.rendering_options['BackgroundColor'] = 'green'
            def auto_create
            	t1 = Time.now
            	sel.empty? ? empty_selection ; with_selection
            	p time = Time.now - t1
            	UI.messagebox(time)
              Your undocumented:
              Sketchup.send_action("makeGroup:")
              doesn't work on [my] PC - BUT:
              Sketchup.send_action(21182)
              does work on [my] PC [but of course that doesn't work on MAC !]
              But if you are working with creating a group from a Selection, then you can use the cross-platform API methods, thus:
              group = Sketchup.active_model.active_entities.add_group( Sketchup.active_model.selection.to_a ); Sketchup.active_model.selection.add( group )
              which mimics those other platform specific 'send_actions' on either OS...
              • G
                Garry K
                auto_create
                0.12499
                I get a big red screen - that is all
                My default template is set to mm with a precision of 0.001
                  driven
                  cheers Tig, I may have gotten there eventually...
                  this works on the mac as suggested...
                  do I need to close the original on a PC for the new one to open with geometry and green background?
                  it's driving nuts as every version I've tried runs on a mac, and each one has been faster that the last...
                  def with_selection
                          group = Sketchup.active_model.active_entities.add_group( sel.to_a )
                          Sketchup.active_model.selection.add( group ) if sel.length > 0
                  	ins = group.to_component
                  	# revert original
                    # re-define for new skp...
                    driven
                    @Garry, the template shouldn't matter...
                    I just can't figure out why you don't get the geometry...
                    This is just a tiny part of a working mac plugin that I'm now porting to PC...
                    on the mac it can grab 100 mixed items from a 1000 item file and cleanly add them to a new model...
                    one test file took 6 hrs to process and delete the 900 unwanted entities, where this take seconds...
                      On a PC an instance of SketchUp is opened for separate for each SKP.
                      On a MAC one instance of SketchUp opens all SKPs.
                      So on a PC, if you you use:
                      Sketchup.open_file("C:/users/tig/desktop/a.skp")
                      its opens that SKP file, BUT closes the current one !
                      But you could use:
                      UI.openURL("file:///#{full_path_to_skp}")
                      which, on a PC, will open the specified SKP in a new instance of SketchUp [and it'll probably work on a MAC, but then it'll be using the same SketchUp]...
                        driven
                        @tig said:
                        ...But you could use:
                        it works exactly the same as open_file on a mac...
                        you can pass the new model to the next ruby method...
                        on a PC, I assume a new instance would need manual intervention to carry on to step 2 of any ruby script?
                        Are there ways around that?
                        I'm starting to see why 'component_edit_window' has so many observers...
                          driven
                          @tig said:
                          So on a PC, if you use:
                          on re-reading this and it may be all I need...
                          i.e. opens the new_skp [containing the selection] in the current ruby session...
                          Is that what happens?
                          keeping the original open isn't a requirement, in fact I'm wanting to preserve intact, and run my actual tool which is destructive on the copy/sub-set...
                            Yes, opening a second SKP in the same SketchUp preserves the current Ruby settings from the first SKP.
                            If you open up a second SketchUp, then the first SKP's Ruby set up is potentially in accessible.
                            Of course, in the first SKP you could write some 'defaults' out to SketchUp [i.e. into the PC Registry], and read those back in, while inside the second SKP, but you then need to load/run some code ?
                              driven
                              cheers Tig,
                              the plugin runs my 'selector' tool after new_skp has been cleaned up...
                              the 'selector' can be scaled, rotated or moved before running the cuts...
                              any solids remain solids afterwards...
                              I need a PC version to attract more testers...
                              With your input, this post could be even better šŸ’—
