    Spline from face
    6 Posts 3 Posters 8.2k Views 3 Watching
    • mwdsM Offline
      mwds
      Hi All,
      I have used AutoCad in the past to generate a spline from an object (face / rectangle / etc.) and then offset this spline to a given distance.
      Is there a tool / plugin for this operation in SketchUp (preferably) or Layout?
      Many thanks in advance.
      Mike
        Make a "section" from a volume ? (Tool Section Plane)
        • mwdsM Offline
          mwds
          Thanks for the reply and those who read my post. Perhaps I didn't explain myself so sorry for the confusion. Below is what I'm trying to achieve; The Yellow object is a face. The Green object is that face converted to a spline. The Magenta object is a representation of the Green spline offset a given distance.
          This is used by me when describing the clearance from the original object (in this case a building) and any zone to be kept free of obstacles. Eg. - If you need to describe the vegetation exclusion zone around a building for the purpose of bushfire protection, for instance.
          Therefore, I need to draw the building perimeter, and then offset a spline to a certain distance. This is easy to do in AutoCAD, but it's an additional step I'm trying to avoid.
          Thanks again in advance for the assistance. πŸ˜„
            Maybe this ?
            Artisan by Dale Martens (Whaat) or SUbD by Thomthom
            Just resize a little the "rounding curve" when calculated (not made here)
            and that will be perfect! πŸ˜„
            Clean Up by Thomthom
            PS Advantage to put always an image when a question is asked! πŸ€“
            Text is never sufficient! πŸ’š
            Everyone wins some times! πŸ˜„
            • mwdsM Offline
              mwds
              Alright... 😎 😎 😎 😎 😎 😎 😎
              Super happy. That work great. Cheers. I owe you a beer.
              Mike
              • pbacotP Offline
                Might look at Curvizard as well.
