    Introducing SUbD for SketchUp...
    Scheduled Pinned Locked Moved SUbD
    renderpluginsextensions
    66 Posts 19 Posters 35.6k Views 19 Watching
    • dereiD Offline
      derei
      @pilou said:
      Principal interest is that avoid any problem with textures deformation, UV, etc...! ๐Ÿ˜‰
      Yeah, cool ๐Ÿ˜„ ... may I have some guidance with this modelling technique? I mean... i believe is not just making squares? There must be something more, deeper. Something that eludes me? ๐Ÿ˜ฒ
      DESIGNER AND ARTIST DEREI.UK
      • panixiaP Offline
        panixia
        @derei said:
        some "specific type of quads" - compatible with SUbD, or any other workflows... what does it means? What makes those quads compatible, as opposed to others?
        a quadface tools quad is a couple of triangle joined by an edge marked as diagonal. the quadface tools "tag" to mark a diagonal is that the edge should be set to soft AND smooth AND not cast shadow (you can check this in entity info window)
        • JQLJ Offline
          JQL
          Quadfaces are basically surfaces with four sides and no divisions inside and are usually handled by other software without the need for the four edges to be coplanar. Sketchup doesn't allow a single face (surface) to be a basic entity if it is not coplanar. It allows for faces to have any number of sides but they must be coplanar (ngons).
          As has been told before, the main 2 advantages of quad faces are:
          • A texture is rectangular so it can be fit easily inside a quad;
          • A quad is a very easy to understand shape that can be easily subdivided, split and modified and still maintain subquads.
          • This will have a lot of advantages but to do it inside sketchup is (until now) simply put insane.
          Thomthom's quadface convention, wich is the first quadface convention on Sketchup, makes a lot of sense and also was adopted by other plugin authors on some plugins.
          However only with SubD plugin the subdivision advantage of quadfaces is really being pushed forward, so the workflow for quadfaces is now going to be explored more than ever.
          I'm personally not ready for it yet...
          www.casca.pt
          Visit us on facebook!
            @derei said:
            Is it any specific workflow in working with quads in SU?
            There are some plugins that claim to do some "specific type of quads" - compatible with SUbD, or any other workflows... what does it means? What makes those quads compatible, as opposed to others?
            I used SketchUp for a very long time, but I never tried to use a "specific" workflow, I just did it how I found best. Now I have a weird sensation that I skipped something...
            Have a look at the introduction overview to quads:
            http://evilsoftwareempire.com/subd/quads
            Make sure to follow the external links about topology.
            I also started on a list of extensions that are compatible with QuadFace Tools quads:
            http://evilsoftwareempire.com/subd/quads/extensions
            The manual of QuadFace Tools also illustrates some of the benefits you can do with quads:
            https://bitbucket.org/thomthom/quadface-tools/wiki/Home
            The tools in QFT is possible only when the mesh is of a predictable nature - which quads provide.
              Recap of the links on topology:
              "Modeling with quads or triangles - what should I use?"
              http://blog.digitaltutors.com/modeling-with-quads-or-triangles/
              So why choose quads?
              When modeling with quads, the wireframe will have a much cleaner look and the model will be easier to navigate and edit. When you spend hours working on a project, you deserve to show it off. But, if the wireframe is messy you become very limited to what you can actually put out in the world for everyone to drool over. When you use quads you create clean, sleek lanes of polygons that are easy to follow through the model and provide beautiful edge flows that you can be easily modified by you or a team member. It is less distracting when you overlay the wireframe on a clay shaded model or even a textured asset.It is also good to work in quads if you plan on passing the model off to someone else or a team. It is easier for someone to convert a model made up of quads to triangles than it is for someone to convert a model made up of triangles to quads.
              "Why Are Ngons and Triangles so Bad?"
              http://blog.digitaltutors.com/ngons-triangles-bad/
              A very important reason for avoiding ngons and triangles is that quads are really the industry-accepted polygon. If you send in a 3D modeling demo reel with a wireframe overlay and your modelโ€™s topology is made up of a miss match of quads, triangles and ngons of all different edge amounts then the message youโ€™re sending the recruiter is that you donโ€™t spend the time to properly topologize your model to work within the other areas of the pipeline like texturing, rigging and animating.
              Topology Guides
              A nice series of visual examples of topology with quads aimed at subdivision:
              http://topology-guides.tumblr.com/
              Quads, Tris, & N-Gons
              https://resources.squid.io/checkmate-3d-modeling-standard/checkmate-specifications-overview/checkmate-pro-checklist/tris-quads-n-gons/
                All that are translated in French here! ๐Ÿ˜‰
                • dereiD Offline
                  derei
                  How does the PushPull for Quads works? And where is it intended to work? I tried it and... the result was something that I didn't quite expected. And what i could have achieved with the normal push-pull, if i would have applied on a single triangle.
                  Please see attached. Also notice that hovering the tool highlighted the quad, but pushing only affected one triangle in the subdivided quad.
                  Thak you
                  • panixiaP Offline
                    panixia
                    it's not intended to work like "joint push pull", so if the face is triangulated, it actually pulls only the single triangle that you pick.
                    this is intendended to quickly extrude loops in some first stage.. the difference beetween this and regular pushpull is that, if you hold down ctrl it creates a new loop without generating an interior face (which would prevent sub-d to work).
                      Why not use the Interactive Joint Push Pull by Fredo6 ? ๐Ÿ˜‰
                      • olisheaO Offline
                        olishea
                        is there a way to offset all these faces in couple clicks? Like multi face offset but on curved surface? Multi face offset TOS? ๐Ÿ˜„
                        oli
                        • Bob JamesB Offline
                          Bob James
                          Isn't that what Fredo6's Interactive Joint Push Pull does?
                          • dereiD Offline
                            derei
                            Oh, I got it now. Is like the Artisan's PushPull (i already use Artisan). Ok then, I have two redundant tools ๐Ÿ˜„ Got it.
                            • dereiD Offline
                              derei
                              [attachment=0:3h8qbjv8]<!-- ia0 -->jointpp.jpg<!-- ia0 -->[/attachment:3h8qbjv8]
                              i use it... but my question was about SUbD pushpull, to understand what is its purpose.
                              Now I got my answer.
                              • dereiD Offline
                                derei
                                After a quick play with SUbD, i noticed that one feature would be GREAT to have:
                                -some sort of "selection sets" for creased edges/vertices. When selecting more edges and crease them together, maybe i want to come back to same set to adjust them further. Every time I have to manually select them all, which is a bit of a pain when there are many. But if there would be a way to select all edges that were creased in the same set, would be awesome.
                                How I am thinking it can be accomplished: using attribute dictionaries, for example. Giving a sort of unique ID to all edges that were creased simultaneously, so when the selection tool looks for which edges to select, it will filter them out by this unique id.
                                I already saw that the creased edges are displayed in a "red" color, which red value varies depending on how creased it is. So, i am assuming those edges are already recognized... maybe selecting them as a "set" would be a easy step to add.
                                • panixiaP Offline
                                  panixia
                                  Pilou, that's great and i use it a lot, but unfortunately, not in this kind of models, because as it is it doesn't support quads.. 90% of the cases it will break them. ๐Ÿ˜ž
                                  • panixiaP Offline
                                    panixia
                                    [attachment=0:33qnbrf7]<!-- ia0 -->push.jpg<!-- ia0 -->[/attachment:33qnbrf7]
                                    i noticed you are also triyng to edit the subdivided mesh. unless you just converted it to "plain mesh" from the right click menu, editing the smoothed mesh is pointless, because when you toggle off sub-d, it will revert back to the original control cage.. and all of the editing done directly on the limit mesh will be lost.
                                    • dereiD Offline
                                      derei
                                      @panixia said:
                                      [attachment=0:15logg0u]<!-- ia0 -->push.jpg<!-- ia0 -->[/attachment:15logg0u]
                                      Thanks ๐Ÿ˜„ ... i found out that myself. The hard way.
                                      • panixiaP Offline
                                        panixia
                                        ๐Ÿ’š ๐Ÿ’š ๐Ÿ’š
                                          Yes - Crease Sets is something I already have on the radar. At the moment I'm thinking of something like a dialog that let you manage a list of creases - such that you can easily locate and manioulate them. One challenge to resolve is how to represent creases with varying creasing - like, what do you do if you adjust a crease with non-uniform crease.
                                          • gillesG Offline
                                            gilles
                                            I create a cube, make it a group, click Toggle subdivision on/off, andโ€ฆ
                                            "OOPS! an error occurredโ€ฆ"
                                            Error; #<NoMethodError; undefined method `commit_operation' for nil;NilClass>
                                            /users/gilles/library/application support/sketchup 2015/sketchup/plugins/tt_subd/commands.rbs;416;in `rescue in set_subdivided'
                                            /users/gilles/library/application support/sketchup 2015/sketchup/plugins/tt_subd/commands.rbs;349;in `set_subdivided'
                                            /users/gilles/library/application support/sketchup 2015/sketchup/plugins/tt_subd/commands.rbs;433;in `toggle_subdivision'
                                            /users/gilles/library/application support/sketchup 2015/sketchup/plugins/tt_subd/commands.rbs;42;in `block in <module;Commands>'
                                            SketchUp;1;in `call'
                                            SketchupMake version 15.3.329
                                            Macbook pro OS X 10.8.5 (12F45)
                                            • 3 / 4
